Filament grouping issue
So since I have updated software I have had an issue with the suggested filament grouping. I have an AMS HT on my left nozzle and and AMS pro on the right. When I slice it is always saying I should have 2-4 filaments on the left nozzle for optimal prints. This never happened before I updated Bambu studio.
Is there any setting I need to change? The studio software and the printer both say I have the AMS HT on left and AMS pro on the right.
When you select Filament Saving Mode for slicing, Studio will give guidance on how best to arrange your filaments for the most efficient printing in terms of minimizing waste.
Unfortunately it doesn’t recognize that there’s no real difference between having the AMS 2 on the left vs the right.
On an H2D with your setup, as long as you have your most used filament in the AMS HT and all the others go to the other nozzle, you’re fine.
To avoid this message,hover over “slice plate” and select Convenience Mode - this slices based on where each filament actually is currently.
Thanks CarbonForge, Bambu used to let me know which filament was the best to put in the left nozzle. Bambu seemed to know I had the HT on the left nozzle (one filament) and the pro on the right (4 filaments) I used to slice and see what bambu said was the best setting and load filament accordingly. It never suggested more than one on the AMS HT side. Thats why I’m asking. I assumed Bambu would slice and let me know which setting will save the most time and filament per set up. makes sense?
I think the new software upgrade doesn’t recognize ones particular set up
