Hi, just an idea, not sure how complicated it would be to do it but maybe you could add section in bambu studio that would work as filament stock/library. Fot those with AMS and lots of filaments it would be a great addition, It would show all my filaments, Bambu filaments would be added to library automatically, and since they have chip with serial number they could automatically count how much of each filament left on the spool. it would simply subtract filament used for all the prints from the spool based on the serial number.
For other brands of filaments or those without the AMS this could be a semi automatic process - you would need to add all rolls to the library and select manually from the library list each roll when you load it in. then until the roll is not changed it would subtract filament from this roll.
I think this would be nice.
I am looking for a solution to this problem right now as well.
Ideally, I would be able to query stock availability as well as out of stock.
This query would be programmatic such as rest.
Would love this feature too!
Great idea, even if only it worked with Bambu filaments. Even if initially you had to manually update stock levels.
Show you what you have, setup alerts when they get blow certain amount and ability to automatically build an online order on Bambu store. This should also reflect in the mobile app.
Would be ok if you’re a Bambu only kind of person, but if you have other brand filaments or printers you’d need the ability to manually adjust the amounts anyway.
I like it but I just got an ams ht and whould like it if it could keep track of when I last dryed each filment
