Filament manager is not reporting amount left correctly when using a 500g spool
It calculates the ratio of 500g the same way it would a 1kg, so a full 500g spool is reported as 250g. The RFID info clearly indicates that it was a 500g spool, but it looks like the calculations are still made assuming 1000g (version with problem: 2.8.2.61)
Is the 500g spool the same width and has the same outer and inner diameter as the 1kg spool?
If so, it should use exactly the same math.
If not, the math needs to change also.
In my opinion the printer should be showing a bar from 0 to 100% and 100% should be 500g. And I guess, that’s where it might go wrong in studio.
The spool looks the same to me, visually (500g of support filament came with my previous bambu). I don;t know if the 500g spool has changed since then.
i think it starts counting when it sees the RFID tag (when it aligns with the reader) and stops when the filament hits the extruder.
edit That will tell them the length of filament on the spool, and then it seems they have calculated the percentage based on 500 instead of 1000. In theory it requires someone replacing “10” with “5” in one place in the code (or preferably reading it from the RFID), but real firmware code is messy and I don’t know much work it is really.
I noticed that there are trial sets of filament in the store, and thought that they would be 500g, but it seems they are 250g. Those spools are smaller and made of cardboard.
I have bought some filaments in 500g variants also. And those were reported as half full on startup.
Just checked my support material spool and it claims 481g/500g so it seems to work fine on my Bambu Studio version 2.8.4.57
