Filament Manager Weight Not updating
Per the wiki, filament weight should update after each print. It does not specify 1st or 3rd party spools. What am I missing? AMS2 Pro w/ h2c
Sometimes it do, sometimes it don’t for me. The thing I watch for is how much is on a spool when I start. Once I purposely ran a spool out to see what would happen. It stopped (the printer) and when I replaced the spool it finished the print. (My AMS2 fed the replacement filament on chasing the first filament and completed the item.)
One thing I haven’t seen is my AMS2 transfer to a second spool when one ran out. But for me it does not matter. I just forge ahead. Overall, I’ve been happy and satisfied with my BL equipment.
I think the remaining volume is just an estimate. A broad estimate. If you remove a spool and put it back in, in my experience it stops keeping track altogether and shows the spool as full, even though it obviously is not. There isn’t any scale per-sey to actually weigh your remaining filament in the AMS2 Pro. Maybe our AMS2 Pro’s just count revolutions. But in any case, don’t hope for accuracy.
So I just eyeball my spools and cross my fingers. :wink:
As I understand it, the remaining filament estimation only works with BambuLab filament because the RFID is used to track the spools.
But apparently the feature is very buggy and repeatedly resets the spools. There is a big forum topic here where this has been discussed a lot.
If it works, it should be fairly accurate. I think It uses the calculated amount of each print job.
