Filament not pushing through the Nozzle / Clicking Sound
Hello, I have like 500 hours now in my A1 and last night, filament suddenly does not load on the nozzle. The filament is stuck inside thus I cant do a cold pull and when I get to push a filament in, the issue goes back again when the toolhead is pushing in a new filament from the AMS.
I tried re assembling the toolhead itself. Extruder seems normal, nozzles are fine I guess. Please help I’m out of ideas huhu. TIA
this is the video of the clicking which happens every time a new filament goes through
This is what the nozzle looks like. Two nozzles are like this already
You need to heat the nozzle and push a nozzle cleaning needle into the nozzle end, then try pushing it out with an allen wrench. If you used something with a higher melting point than PLA, you’ll have to raise the temperature higher than the directions tell you for the extruder.
Follow the same steps here for the A1 mini
Next step, remove the extruder gears and clean them. They’re probably clogged with ground plastic because of the filament not feeding.
Sadly the same issue persist :frowning: Might order a new extruder but it’s kinda sad as I only had the printer for only 4 months
Although Im not sure if the extruder is the problem as the filament does go through if the nozzle is empty. All my 3 nozzle is experiencing this so I dont really know what the problem is
@Gidipi I am having this same issue. Did you ever find a resolution?
Sounds like a normal clog, but make sure your nozzle is heating correctly. You can remove a lot of variables dealing with the extruder and ams etc with a simple test - You should be able to set the machine to 210C, and with your hands, hold down the extrusion tension lever, and push PLA thru from the top. If it’s not coming out, you have a clog or its not heating.
Clogs can be addressed lots of ways, common ways are the needle poke, a cold pull, or 1.5mm hex wrench rams. Wiki has steps A1/A1 mini Nozzle/Hotend Unclogging Procedure | Bambu Lab Wiki
I have the same problem since the new software update. I cleaned the extruder and the nozzle, even tried a new nozzle, and got stuck again. I ruined the original 0.4 nozzle trying to unclog it. I only use Bambu Lab PLA and did not have any problems until yesterday when I updated my software. Now it does not work as before; it always goes fine for 2 minutes, and after that, it starts clicking and clogging the nozzle.
Sorry to hijack the thread but its pretty close to my issue as well and I am to much of a newb here as far as 3d printing goes.
So, like this thread, My A1 has been printing pretty much nonstop for nearly 3k hours and much of that time it was working just fine… I mean I had to learn about ironing and scarfs and supports and using new software etc, but all of a sudden a week ago I started getting intermittent spaghetti that just as quickly disappeared but was replaced with the extruder clicking internally and the nozzle scraping along the print pad for the first lay which was ultimately damaging the print plate as well as tearing up the print job. In observing things as they happened I noticed that the actual print head, the hot end, would be pushed downward a millimeter or 2 and then “snap” back into place. My observation sees this happening with the clicking noise, with the print nozzle dragging across the print bed, I know that the nozzle dragging is a Z issue and yes I have found the magic 29.1 setting for first layer issues, and I have auto calibrated and leveled so many times that My 1980’s era D&D character would be a god level from all the practice and experience. lol
The magic 29.1 does not make a hill of beans difference, - or + with trial ranging from -1.0 to - 0.1 to -0.01 to 0 to +0.01 all the way up through +2.0.
I did take the extruder, as well as the hot end, apart and clear out what little dust and debris out. I did find that the screws on the back of the hot end had come loose and that was allowing the nozzle to shift about relatively freely so I tightened them and tested everything… nada, still the clicking and still the nozzle visibly shifting down and snapping back up into place over and over and over and over an..(clicking stop print job for the hundredth time).
It happens with every spool of filament I have (mostly all pla but one spool of tpu for ams) and only happens when actually trying to print the first layer. In My testing of things to try and resolve it all I did cold pulls as recommended, and in maintenance mode where the nozzle was not over/on the print bed it extruded just fine. So the clicking is only during the first layer printing and only when actually over the print bed.
I have taken the extruder all the way apart, cleaned, and rebuilt it.
I have cleaned the print bed with hot soapy water and then an isopropil alcohol bath to finish it off.
I have done and redone and redone the done with G29.1 Z. I have used hyperlock and tried super tac, cold print plate, regular ole textured plates, changed out .4 nozzles with hard ones and back to stainless as well as trying 0.2 and 0.6 nozzles.
Heck I have even factory reset the printer 3 times now.
During this time I got a second A1 w AMS and have it set up and loaded into bambu handy and printed the exact same print job to it as the first A1 was trying to do the same plate.
All I can think of now is to just yank the ripcord and purchase and install a whole new extruder set.
I even thought maybe it was a slicer issue but printing on the 2nd printer with the exact same job and it works perfectly tells Me that its not a slicer issue.
I have spent days trying to figure this out, reading all tge wiki and anywhere else I can find information but nothing seems to even make a dent in the issue.
Help…. please
Please tell me you’ve found a solution for this. I have the exact same issue, and I think I wasted 6h trying everything, with creality ender 3’s flashbacks of war.
