Filament on nozzle interferes with bed leveling
Hi,
since two weeks I have some issues on my X1C with filament sticking on the nozzle during bed levelling.
I always use PLA from eSun or Bambu.
Everything works well during the bed levelling phase where the nozzle hammers to the build plate.
Then, before the next step, the head goes back to the wiper - the nozzle has a temperature of 140 degrees - it pushes a small amount of filament out (2-3cm) which sticks on the nozzle.
I assume this leads to bed levelling errors followed by first layer- and spaghetti errors.
I performed the maintenance steps, replaced the hotend, the nozzle wiper, tried different filaments, downgraded firmware to 1.04.01 (as suggested in another thread), nothing helps. I was using the printer for 3 months and never had any issue.
At the moment I have to wait until the printer starts with the first line to see if there is a distance between nozzle and build plate. If leveling was fine the prints are nearly perfect.
Suggestions are welcome.
Thanks
Karsten
It lowers the nozzle temp so that it does not damage the bed when leveling from too high of a temp.
When I look at the machine start code for the P1P it does multiple nozzle wipes, retracts, lowers temp and then rubs the nozzle on the back edge of the plate to make sure there is nothing on the end of the nozzle.
Are you seeing the rubbing on the back of the plate before leveling?
Hi,
Thanks. Yes. I can see the rubbing and at this time the nozzle is clean.
Then the part where nozzle knocks several times on the plate starts and still everything is fine.
After that part the head goes to the poh section and stays for a few seconds. Then it extrudes 2-3cm filament (at 140 °) which keeps sticking during the following steps. I don’t understand why the machine is doing it? Can I modify the G-Code to bypassing this step?
Normally it should lower the temp to 140° AFTER the extrusion.
And yes, you can modify the machines GCode.
Line 121:
M104 S140 ; set temp down to heatbed acceptable
And this is the original GCode:
;===== machine: X1 =========================
;===== date: 20230130 =====================
;===== reset machine status =================
G91
M17 Z0.4 ; lower the z-motor current
G0 Z12 F300 ; lower the hotbed , to prevent the nozzle is below the hotbed
G0 Z-6;
G90
M17 X1.2 Y1.2 Z0.75 ; reset motor current to default
M960 S5 P1 ; turn on logo lamp
G90
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
M73.2   R1.0 ;Reset left time magnitude
M1002 set_gcode_claim_speed_level : 5
M221 X0 Y0 Z0 ; turn off soft endstop to prevent protential logic problem
G29.1 Z{+0.0} ; clear z-trim value first
;===== heatbed preheat ====================
M1002 gcode_claim_action : 2
M140 S[bed_temperature_initial_layer_single] ;set bed temp
M190 S[bed_temperature_initial_layer_single] ;wait for bed temp
{if scan_first_layer}
;=========register first layer scan=====
M977 S1 P60
{endif}
;=============turn on fans to prevent PLA jamming=================
{if filament_type[initial_tool]=="PLA"}
    {if (bed_temperature[current_extruder] >45)||(bed_temperature_initial_layer[current_extruder] >45)}
    M106 P3 S180
    {elsif (bed_temperature[current_extruder] >50)||(bed_temperature_initial_layer[current_extruder] >50)}
    M106 P3 S255
    {endif};Prevent PLA from jamming
{endif}
M106 P2 S100 ; turn on big fan ,to cool down toolhead
;===== prepare print temperature and material ==========
M104 S[nozzle_temperature_initial_layer] ;set extruder temp
G91
G0 Z10 F1200
G90
G28 X
M975 S1 ; turn on
G1 X60 F12000
G1 Y245
G1 Y265 F3000
M620 M
M620 S[initial_tool]A   ; switch material if AMS exist
    M109 S[nozzle_temperature_initial_layer]
    G1 X120 F12000
    G1 X20 Y50 F12000
    G1 Y-3
    T[initial_tool]
    G1 X54 F12000
    G1 Y265
    M400
M621 S[initial_tool]A
M412 S1 ; ===turn on filament runout detection===
M109 S250 ;set nozzle to common flush temp
M106 P1 S0
G92 E0
G1 E50 F200
M400
G92 E0
G1 E50 F200
M400
M106 P1 S255
G92 E0
G1 E5 F300
M109 S{nozzle_temperature_initial_layer[initial_extruder]-20} ; drop nozzle temp, make filament shink a bit
G92 E0
G1 E-0.5 F300
G1 X70 F9000
G1 X76 F15000
G1 X65 F15000
G1 X76 F15000
G1 X65 F15000; shake to put down garbage
G1 X80 F6000
G1 X95 F15000
G1 X80 F15000
G1 X165 F15000; wipe and shake
M400
M106 P1 S0
;===== prepare print temperature and material end =====
;===== wipe nozzle ===============================
M1002 gcode_claim_action : 14
M975 S1
M106 S255
G1 X65 Y230 F18000
G1 Y264 F6000
G1 X100 F18000 ; first wipe mouth
G0 X135 Y253 F20000  ; move to exposed steel surface edge
G28 Z P0 T300; home z with low precision,permit 300deg temperature
G29.2 S0 ; turn off ABL
G0 Z5 F20000
G1 X60 Y265
G92 E0
G1 E-0.5 F300 ; retrack more
G1 X100 F5000; second wipe mouth
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X90 F5000
G0 X128 Y261 Z-1.5 F20000  ; move to exposed steel surface and stop the nozzle
M106 S255 ; turn on fan (G28 has turn off fan)
M221 S; push soft endstop status
M221 Z0 ;turn off Z axis endstop
G0 Z0.5 F20000
G0 X125 Y259.5 Z-1.01
G0 X131 F211
G0 X124
G0 Z0.5 F20000
G0 X125 Y262.5
G0 Z-1.01
G0 X131 F211
G0 X124
G0 Z0.5 F20000
G0 X125 Y260.0
G0 Z-1.01
G0 X131 F211
G0 X124
G0 Z0.5 F20000
G0 X125 Y262.0
G0 Z-1.01
G0 X131 F211
G0 X124
G0 Z0.5 F20000
G0 X125 Y260.5
G0 Z-1.01
G0 X131 F211
G0 X124
G0 Z0.5 F20000
G0 X125 Y261.5
G0 Z-1.01
G0 X131 F211
G0 X124
G0 Z0.5 F20000
G0 X125 Y261.0
G0 Z-1.01
G0 X131 F211
G0 X124
G0 X128
G2 I0.5 J0 F300
G2 I0.5 J0 F300
G2 I0.5 J0 F300
G2 I0.5 J0 F300
M109 S140 ; wait nozzle temp down to heatbed acceptable
G2 I0.5 J0 F3000
G2 I0.5 J0 F3000
G2 I0.5 J0 F3000
G2 I0.5 J0 F3000
M221 R; pop softend status
G1 Z10 F1200
M400
G1 Z10
G1 F30000
G1 X128 Y128
G29.2 S1 ; turn on ABL
;G28 ; home again after hard wipe mouth
M106 S0 ; turn off fan , too noisy
;===== wipe nozzle end ================================
;===== check scanner clarity ===========================
G1 X128 Y128 F24000
G28 Z P0
M972 S5 P0
G1 X230 Y15 F24000
;===== check scanner clarity end =======================
;===== bed leveling ==================================
M1002 judge_flag g29_before_print_flag
M622 J1
    G29 A X{first_layer_print_min[0]} Y{first_layer_print_min[1]} I{first_layer_print_size[0]} J{first_layer_print_size[1]}
    M400
    M500 ; save cali data
M623
;===== bed leveling end ================================
;===== home after wipe mouth============================
M622 J0
    M1002 gcode_claim_action : 13
    G28
M623
;===== home after wipe mouth end =======================
M975 S1 ; turn on vibration supression
    M106 P3 S180
    M106 P3 S255
{endif}
M104 S{nozzle_temperature_initial_layer[initial_extruder]} ; set extrude temp earlier, to reduce wait time
;===== mech mode fast check============================
G1 X128 Y128 Z10 F20000
M400 P200
M970.3 Q1 A7 B30 C80  H15 K0
M974 Q1 S2 P0
M400 P200
M970.3 Q0 A7 B30 C90 Q0 H15 K0
M974 Q0 S2 P0
M975 S1
G1 F30000
G1 X230 Y15
G28 X ; re-home XY
;start heatbed  scan====================================
M976 S2 P1
G90
G1 X128 Y128 F20000
M976 S3 P2  ;register void printing detection
{endif}
;===== noozle load line ===============================
M975 S1
G90
M83
T1000
G1 X18.0 Y1.0 Z0.8 F18000;Move to start position
M109 S{nozzle_temperature[initial_extruder]}
G1 Z0.2
G0 E2 F300
G0 X240 E15 F{outer_wall_volumetric_speed/(0.3*0.5)     * 60}
G0 Y11 E0.700 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
G0 X239.5
G0 E0.2
G0 Y1.5 E0.700
G0 X18 E15 F{outer_wall_volumetric_speed/(0.3*0.5)     * 60}
M400
;===== for Textured PEI Plate , lower the nozzle as the nozzle was touching topmost of the texture when homing ==
;curr_bed_type={curr_bed_type}
{if curr_bed_type=="Textured PEI Plate"}
G29.1 Z{-0.04} ; for Textured PEI Plate
{endif}
;===== draw extrinsic para cali paint =================
M1002 judge_flag extrude_cali_flag
M622 J1
    M1002 gcode_claim_action : 8
    T1000
    G0 F3000 X28.000 Y19.500 Z0.200
    G1 F1200.0 X28.000 Y45.000 Z0.200 E0.933
    G1 F1200.0 X28.500 Y45.000 Z0.200 E0.018
    G1 F1200.0 X28.500 Y19.500 Z0.200 E0.933
    G1 F1200.0 X31.000 Y19.500 Z0.200 E0.091
    G1 F1200.0 X31.000 Y49.000 Z0.200 E1.080
    G1 F1200.0 X37.500 Y49.000 Z0.200 E0.238
    G1 F1200.0 X37.500 Y60.000 Z0.200 E0.403
    G1 F1200.0 X42.500 Y60.000 Z0.200 E0.183
    G1 F1200.0 X42.500 Y49.000 Z0.200 E0.403
    G1 F1200.0 X48.000 Y49.000 Z0.200 E0.201
    G1 F1200.0 X48.000 Y20.000 Z0.200 E1.061
    G1 F1200.0 X30.000 Y20.000 Z0.200 E0.659
    G1 F1200.0 X30.000 Y41.000 Z0.200 E0.769
    G1 F1200.0 X50.000 Y41.000 Z0.200 E0.732
    G1 F1200.0 X50.000 Y34.000 Z0.200 E0.256
    G1 F1200.0 X30.000 Y34.000 Z0.200 E0.732
    G1 F1500.000 E-0.800
    ;=========== extruder cali extrusion ==================
    T1000
    M83
    {if default_acceleration > 0}
        {if outer_wall_acceleration > 0}
            M204 S[outer_wall_acceleration]
        {else}
            M204 S[default_acceleration]
        {endif}
    {endif}
    G0 X35.000 Y18.000 Z0.300 F30000 E0
    G1 F1500.000 E0.800
    G0 X185.000 E9.35441 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G0 X187 Z0
    G0 Z1
    G0 X180 Z0.3 F18000
    M900 L1000.0 M1.0
    M900 K0.040
    G0 X45.000 F30000
    G0 Y20.000 F30000
    G1 F1500.000 E0.800
    G1 X65.000 E1.24726 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X70.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X75.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X80.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X85.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X90.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X95.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X100.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X105.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X110.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X115.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X120.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X125.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X130.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X135.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X140.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X145.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X150.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X155.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X160.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X165.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X170.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X175.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X180.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X183 Z0.15 F30000
    G1 X185
    G1 Z1.0
    G0 Y18.000 F30000 ; move y to clear pos
    G1 Z0.3
    M400
    G0 X45.000 F30000
    M900 K0.020
    G0 X45.000 F30000
    G0 Y22.000 F30000
    G1 F1500.000 E0.800
    G1 X185
    G1 Z1.0
    G1 Z0.3
    M400
    G0 X45.000 F30000
    M900 K0.000
    G0 X45.000 F30000
    G0 Y24.000 F30000
    G1 F1500.000 E0.800
    G1 X185
    G1 Z1.0
    G1 Z0.3
    G0 X45.000 F30000 ; move to start point
M623 ; end of "draw extrinsic para cali paint"
M104 S140
;=========== laser and rgb calibration ===========
M400
M18 E
M500 R
M973 S3 P14
G1 X120 Y1.0 Z0.3 F18000.0;Move to first extrude line pos
T1100
G1 X143.0 Y1.0 Z0.3 F18000.0;Move to first extrude line pos
M400 P100
M960 S1 P1
M400 P100
M973 S6 P0; use auto exposure for horizontal laser by xcam
M960 S0 P0
G1 X240.0 Y6.0 Z0.3 F18000.0;Move to vertical extrude line pos
M960 S2 P1
M400 P100
M973 S6 P1; use auto exposure for vertical laser by xcam
M960 S0 P0
;=========== handeye calibration ======================
M622 J1
    M973 S3 P1 ; camera start stream
    M400 P500
    M973 S1
    G0 F6000 X40.000 Y54.500 Z0.000
    M960 S0 P1
    M973 S1
    M400 P800
    M971 S6 P0
    M973 S2 P16000
    M400 P500
    G0 Z0.000 F12000
    M960 S0 P0
    M960 S1 P1
    G0 Y37.50
    M400 P200
    M971 S5 P1
    M960 S0 P0
    M960 S2 P1
    G0 Y54.50
    M400 P200
    M971 S5 P3
    G0 Z0.500 F12000
    M960 S0 P0
    M960 S1 P1
    G0 Y37.50
    M400 P200
    M971 S5 P2
    M960 S0 P0
    M960 S2 P1
    G0 Y54.50
    M400 P500
    M971 S5 P4
    M963 S1
    M400 P1500
    M964
    T1100
    M960 S0 P1
    M973 S1
    M400 P800
    M971 S6 P0
    M973 S2 P16000
    M400 P500
    G0 Z0.000 F12000
    M960 S0 P0
    M960 S1 P1
    G0 Y37.50
    M400 P200
    M971 S5 P1
    M960 S0 P0
    M960 S2 P1
    G0 Y54.50
    M400 P200
    M971 S5 P3
    G0 Z0.500 F12000
    M960 S0 P0
    M960 S1 P1
    G0 Y37.50
    M400 P200
    M971 S5 P2
    M960 S0 P0
    M960 S2 P1
    G0 Y54.50
    M400 P500
    M971 S5 P4
    M963 S1
    M400 P1500
    M964
    T1100
    G1 Z3 F3000
    M400
    M104 S{nozzle_temperature[initial_extruder]} ; rise nozzle temp now ,to reduce temp waiting time.
    T1100
    M400 P400
    M960 S0 P0
    G0 F30000.000 Y22.000 X65.000 Z0.000
    M400 P400
    M960 S1 P1
    M400 P50
    M969 S1 N3 A2000
    G0 F360.000 X181.000 Z0.000
    M980.3 A70.000 B{outer_wall_volumetric_speed/(1.75*1.75/4*3.14)*60/4} C5.000 D{outer_wall_volumetric_speed/(1.75*1.75/4*3.14)*60} E5.000 F175.000 H1.000 I0.000 J0.020 K0.040
    M400 P100
    G0 F20000
    G0 Z1 ; rise nozzle up
    T1000 ; change to nozzle space
    G0 X45.000 Y16.000 F30000 ; move to test line pos
    M969 S0 ; turn off scanning
    M960 S0 P0
    G1 Z2 F20000
    T1000
    G0 X45.000 Y16.000 F30000 E0
    G0 Z0.3
    G1 F1500.000 E3.600
    ; see if extrude cali success, if not ,use default value
    M1002 judge_last_extrude_cali_success
    M622 J0
        M400
        M900 K0.02 M{outer_wall_volumetric_speed/(1.75*1.75/4*3.14)*0.02}
    M623
    G1 X180.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X185.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X190.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X195.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X200.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X205.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X210.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X215.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    G1 X220.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}
    G1 X225.000 E0.31181 F{outer_wall_volumetric_speed/(0.3*0.5)    * 60}
    M973 S4
M623
;========turn off light and wait extrude temperature =============
M1002 gcode_claim_action : 0
M973 S4 ; turn off scanner
M400 ; wait all motion done before implement the emprical L parameters
;M900 L500.0 ; Empirical parameters
M960 S1 P0 ; turn off laser
M960 S2 P0 ; turn off laser
M106 P2 S0 ; turn off big fan
M106 P3 S0 ; turn off chamber fan
M975 S1 ; turn on mech mode supression
G90
M83
T1000
G1 E{-retraction_length[initial_extruder]} F1800
G1 X128.0 Y253.0 Z0.2 F24000.0;Move to start position
G1 E{retraction_length[initial_extruder]} F1800
M109 S{nozzle_temperature_initial_layer[initial_extruder]}
G0 X253 E6.4 F{outer_wall_volumetric_speed/(0.3*0.6)    * 60}
G0 Y128 E6.4
G0 X252.5
G0 Y252.5 E6.4
G0 X128 E6.4
Copy&Paste it. Maybe there is an error in your version :roll_eyes:
what is the “poh section”
I am looking at the X1 machine start code now.
When you say the nozzle “knocks several times on the plate” are you talking about in the middle of the plate? If so that is homing the Z axis.
I am not familiar with the X1 code as I have a P1P. The X1 has much more startup code and a significant portion of it is in run-time conditional statements (M622).
It looks like this is the actual home, which occurs after bed leveling.
M622 J0
G28
M623
shortly after that it heats the nozzle to first layer temp.
M622 J0
G28
M623
You are probably better off using the previous suggestion. I do think it is worthwhile to try to undestand the start code when you have time. Maybe print a copy and look at it during a print start to try and identify what happens when. That is how I figured out and optimized my start code.
Hi, thanks for sharing. Before I try I will try to understand the G-Code.
See you, Karsten
With knocking on the plate I mean the phase where the nozzle touches the whole build plate (one point after another). Then the head goes back to the purge area, extrudes the 2-3 filament and after that it scans the build plate without touching it (withe the filament sticking on the nozzle). Sorry, if I don’t express it with the right words.
But if I am able to find the place in G-Code where this extruding with 140° happens, I am sure, I can solve the problem.
I will try to record a short movie about the issue.
Thanks to all replies!
See you,
Karsten
That part is the bed leveling process.
Do not worry about how you say it. You are getting the information across.
Hopefully someone with an X1 will add more information soon.
Did you ever fix this issue? I am having the exact same issue. The only way ive been able to fix it is by keeping a close eye on it and at the exact right moment, reach in scrap that blob of filament off be fore it starts it’s mesh bed leveling.
Not really. At the time I’ve found g-code snippet that I pasted at the end of the “Machine start G-Code”.
This adds an additional nozzle wiping before printing. It helped a little bit but I had still filament on the nozzle during the bed levelling process.
Then I had a longer printing-free period in the summer. After installing the latest firmware in autumn, I have still the same issue but 99% of prints are perfect.
Even with the filament on the nozzle, the levelling seems to work. I printed >20kG of filament since then and had just 1 spaghetti monster and 2 firstlayer errors (one of them was printing ABS with PLA settings - my mistake).
I still have on my list to learn to understand the Machine g-code and find the place where the (in my opinion) useless filament push out of the filament during the leveling process happens (
Filament on nozzle interferes with bed leveling - #3 by karsten.suckow).
Here is the code snippet for the additional step for nozzle wiping before printing. You can paste it at the end of the Machine start Go-Code in the printer settings.
(The use is at your own risk.)
;===== wipe the nozzle before starting printing the object ===============================
G1 X60 Y265
G92 E0
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X90 F5000
;===== wipe the nozzle before starting printing the object end ===============================
