Together like this ?
I don’t think many here will understand that question especially titled “filament question” when it looks like you want to ask something about the enclosure lid and lighting?
Sorry about that, yes ! All together
Yes together ,
I can’t speak too much unfortunately radiation.
If I understand the question (maybe I don’t?) if you are asking if that’s how you install that light, what I can see in photo might be right?
That light looks thin to support an AMS though. Depending on how hot it gets you might want something else to help support the AMS or maybe move it off the top.
But got to say I’m not familiar with that light. It may be plenty strong. Hopefully someone familiar with that light can chime in on if it’s meant to support an AMS.
Good luck, though.
He’s looking for a riser that can hold an led light. I think.
Awesome, but now that’s not it.
This was
https://www.printables.com/model/705391-updated-bambu-glass-top-spacer-vent-holes-and-no-v/files
Closed vents or opened! Unfortunately I have to choose one or another one… I wonder …
Ok.
There are more risers than anyone can mention, and you should be able to find something you like.
I rock the one i gave you a link for because you can use COBB lights and it allows you to remove the top, or raise it for ventalation.
Search Makerworld for LED Riser. You want to be able to either vent at the top or remove your top if you’re printing PLA. Heat rises and will eventually cause you issues.
Awesome thank you so much !!
COB ??
Link? Thank you. Thank you.
Ones similar to these. There is a usb out in the top front of the printer, at least on the P1P. Sure the X1 has one as well, or you can run it out the back of the riser, usually a spot to feed the connector out.
Anytime.
25 awesome lamas
Sounds good, alright thanks lol
