Ran large print overnight.
Filament ran out half way.
Print continued.
How to resume print from any given layer ?
Also how to test if the sensor working at all ?
Not possible on an existing print. You can reprint the remaining layers and glue the parts togther.
First I would check the sensor and see if something is jamming it.
To test it, start a print from an external spool but without any filament loaded. The print should ask you to load filament, Once you load it, it should continue with the print.
You can test the runout sensor by cutting the filament while printing and see if it pauses the print when the filament clears the sensor.
Nothing is jamming.
Latch inside sensor moves freely.
I tried to extrude manually using STUDIO and it keeps extruding even when there is no filament.
I tried to start a print without filament, print started.
Maybe this is because of my GCODE ?
M960 S5 P0
;===== machine: P1S =====
;===== date: 20240229 =====
;===== Version 6 - FINAL =====
;===== start G-Code by Schmudi =====
;===== !!! use at your own risk !!! =====
;===== P1S firmware: 1.05.02 =====
;===== AMS firmware: 00.00.06.40 =====
;===== reset machine status =================
G90
M17 X1.2 Y1.2 Z0.75 ; set motor current to default
M290 X40 Y40 Z2.6666666; Use Babystepping
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
M73.2 R1.0 ;Reset left time magnitude
M1002 set_gcode_claim_speed_level : 5
M221 X0 Y0 Z0 ; turn off soft endstop to prevent protential logic problem
G29.1 Z{+0.0} ; clear z-trim value
M204 S10000 ; init ACC set to 10m/s^2
;=============turn on fans =================
M106 P1 S125 ; Part fan
M106 P2 S50 ; AUX Fan
;M106 P3 S125; Chamber fan BAMBU
M710 A1 S255; MC-board fan automatic
;===== heatbed preheat and home ====================
M1002 gcode_claim_action : 2
M140 S[bed_temperature_initial_layer_single] ;set bed temp
M104 S180; set extruder temp - low value to avoid blobs while homing
M190 S[bed_temperature_initial_layer_single] ;wait bed temp
M1002 gcode_claim_action : 13
G28 T300; Homing - permit 300deg temperature
M400 ; wait for finish homing
;===== prepare print temperature and material ==========
M1002 gcode_claim_action : 7
M104 S{nozzle_temperature_range_high[initial_extruder]} ;wait extruder temp
G91
G1 Z10 F1200
G90
M975 S1 ; turn on mech mode supression
G1 X67 F12000
G1 Y240
G1 Y265 F3000
;===== bed leveling ====================
M1002 judge_flag g29_before_print_flag
M622 J1
G29 A X{first_layer_print_min[0]} Y{first_layer_print_min[1]} I{first_layer_print_size[0]} J{first_layer_print_size[1]}
M400
M500 ; save cali data
M623
;===== prepare AMS ==========
M1002 gcode_claim_action : 4
M620 M
M620 S[initial_extruder]A ; switch material if AMS exist
G1 X120 F12000
T[initial_extruder]
G1 X54 F12000
G1 Y265
M400
M621 S[initial_extruder]A
M620.1 E F{filament_max_volumetric_speed[initial_extruder]/2.4053*60} T{nozzle_temperature_range_high[initial_extruder]}
;===== for Textured PEI Plate , lower the nozzle as the nozzle was touching topmost of the texture when homing ==
curr_bed_type={curr_bed_type}
{if curr_bed_type==“Textured PEI Plate”}
G29.1 Z{-0.05} ; for Textured PEI Plate; personal PEI plate - corrct value to your own plate
{endif}
{if curr_bed_type==“High Temp Plate”}
G29.1 Z{-0.00} ; for smooth PEI-plate
{endif}
;======== wait extrude temperature and prefill =============
M106 P3 S220 ; Chamber Fan BAMBU
; M106 P3 S25 ; Chamber Fan NOCTUA
G29.2 S1
M190 S[bed_temperature_initial_layer_single] ;set bed temp
M109 S[nozzle_temperature_initial_layer] ;set extruder temp
M1002 gcode_claim_action : 0
G92 E0
G92 E0.2 F200
G92 E0
;===== wipe nozzle #2 ===============================
G4 P5000
M1002 gcode_claim_action : 14
M975 S1
M106 P1 S255
G1 X65 Y230 F18000
G1 Y264 F6000
G1 X100 F18000 ; first wipe
G29.2 S0 ; turn off ABL
G0 Z5 F12000
G1 X60 Y265
G1 X100 F5000; second wipe
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X90 F5000
M400
G1 Z10
G29.2 S1 ; turn on ABL
M975 S1 ; turn on vibration supression
M106 P1 S125 ; Part fan on
Switch back to the default start gcode and see if that fixes the issue.
Manually extruding doesn’t use in the filament sensor.
It worked. But i need to know why
