Although there have been several topics about this in the past, most are more than 2 years old. I wanted to start a new one to highlight that it seems to be a universal problem.
TL;DR: Why do filament manufactures make us want to buy filament on “reusable” plastic spools when it’s better for us to just toss the spools into recycling than to buy refill filament? How can we convince them to do better?
Bambu PLA refills cost $15/kg, but the only way to buy is two-roll packs of the same color. If you buy Bambu PLA wrapped around a plastic spool, it is more expensive, but you only need to buy 4 rolls to get enough discount to make each roll cost the same ($15). If you buy more than 4, the price can go down even more. You also don’t have to match colors to get the discount…you can buy any color as long as you buy 4 rolls.
Then, there’s the fact that Bambu has 30 colors of PLA to choose from if you buy rolls on plastic spools, while refills have only 5 color choices.
But, enough bashing Bambu…they might not have the best refill policy, but it’s also not the worst.
Sunlu will sell you a 1kg filament refill for $12.50, while the same filament on a plastic spool is $11.50. Refills are flat out more expensive from Sunlu. They do at least have a better selection of colors on refill (20), but that’s still less than the 38 available on plastic spools.
eSun is pretty much the same…$16.80 for a refill, and $16 for the same filament on a cardboard spool. They don’t even sell reusable plastic spools, but they do sell refills, which at least is an attempt at helping the environment. Maybe not having to mess with cardboard spools in whatever automatic filament loading system you have is worth the extra $0.80. But, they still have a much worse color selection (27) on refills compared to spools (45).
So, what can we do to convince filament manufacturers to give us good selection and lower prices on refills? Normally, the suggestion is “vote with your wallet”, but we all seem to be doing that right now, and as long as manufactures keep feeding us deals on non-refills, we will keep buying them.
