I have recently changed nozzles from a 4mm hardened nozzle to a 6mm hardened nozzle. HPWEVER, I noticed the ‘filament settings’ only show a 8mm option which causes the software to recognize the difference. How do I change that? Or is there an option I have not seen?
I have the exact same thing. Switched to the 0.6mm nozzle today and just realized, that the filament profile shows 0.8mm. It also shows the X1C, not the P1S that I have. Confusing…
I have a print running at the moment, one that I’ve previously printed with a 0.4mm nozzle. I will let you know if anything looks weird.
For some reason I am not allowed to upload screenshots, so… Here you go: https://imgur.com/a/JXszyva
Thanks, and yes I had them selected.
Oh good, glad that it’s not just a ME thing haha.
I am trying to use CR filament, and in Bambu Lab have changed the nozzle to the hardened steel 0.6 diameter nozzle, and set the nozzle size to 0.6. BUT, after slicing and trying to send the print, I get this message.
“The current nozzle) diameter (0.4mm) does not match the slicing file (0.6mm). Please make sure the nozzle installed matches with the settings in printer, then set the corresponding printer preset when slicing.”
The screen that displays this message (sending to the printer), shows that the printer is set to 0.4mm, but in the Prepare and Preview screens, even the printer settings screen is shows the printer nozzle set to 0.6mm.
I’m baffled at what I’m doing wrong, or if this is a bug?
Would love to upload a screenshot…
Bump… can’t print CF without this nozzle. Anyone?
My OP should say, CF, not CR.
Printer is an A1
