It doesnt sound like anything is wrong. When you unload, the filament will be cut about 5mm above the top of the hotend. Which means sometimes you have to pull down and out.
Till now I had changed aux nozzle only once (several times on the main extruder). But yes, it seems, that on the aux nozzle the cut is higher and you have to fiddle a bit. Before reinserting I shorten the filament to make life easier…
Sorry if these are very basic questions — this is my first 3D printer and I just want to make sure I don’t damage anything.
I want to replace the left/main nozzle with a 0.2 mm nozzle.
Do I need to remove the right nozzle first, or can I directly remove the left one?
Also, is there always some filament left inside the nozzle after use? I tried removing the right nozzle before and it wouldn’t come out, apparently because a piece of filament was still inside.
If so, what is the correct procedure before removing a nozzle? Should I unload first, heat it, or use the filament cutting tool? If I need to cut the filament, where exactly should I cut it?
Hello @Mehdi, these are the answers I obtained from my experience using the X2D
For the left nozzle this depends on wether you use the AMS or not. If you do use the AMS then you can just take out the left nozzle right away (no need to unload), since the AMS retracts the filament after each print.
If you don’t use the AMS (External Spool) then you would need to select the unload option on the printer screen and wait for the printer to unload the filament first, only then you can remove the left nozzle (after it’s cooled down).
