Filament stops extruding mid air, not clogged
Hello everyone. Thank you for the tips and tricks here in the forum. I have read quite some posts now but could not find a solution yet.
TL;DR:
I have checked the things other people mentioned. My prints are starting fine, and then at some point the extruder stops extruding filament, printing mid air without extruding. Calibration, pre-drying, external spool and AMS feeding was exercised. Please read to the end, this is the short version.
I am trying to print with https://www.3djake.com/3djake/petg-bronze which has been lying around for about 1year. I put it at 50Âş in the oven for about 5 hrs prior printing.
Settings used:
  • 0.4 Nozzle 240Âş
  • Speed: Silent (50%)
  • 70Âş on the PrintBed.
  • Profile: Standard 0.2mm
What happens is, that at random (4 tried yet) the printhead stops extruding filament and continues in the air without giving a warning. Out of the 500 Layers it stops at 50, 90, 240 and 270 (not in that order).
When stopping the print, the filament got cut, pulled back fine. When initiating a “Filamane load” the filament was extracted fine and everything looks good. I could even finish a print with another PLA filament which came out fine and nothing was clogged or jammed.
What I did recognize is, that the end of the PETG (which was pulled back) was visibly thiner than the 1.75mm it has.
I thought maybe a production failure so I slowly re-spooled the filament twice and checked carefully the diameter in front of a white paper, but could not find parts that are visibly thinner.
I have now changed the hotted from 0.4mm to 0.6mm and will try again. Attached is a picture of the 0.4mm hot end with some PETG bronze filament sticking out.
I have read
I read, watched all of the above threads and more. Nothing is clogged and I can print different things in between.
So am am looking for solutions to fix this filament or maybe the model? I have no idea anymore except chasing the filament and throwing away this spool. Which would be bad as it was a 30 Euro one and should not be wasted like this.
While writing this, I am printing again a flow calibration with a 0.6mm nozzle which I installed in the meantime. Maybe this helps. I do not know.
Thank you for reading all the way up the here. If you had the same problem, please let me know and if you found a solution to yours, please also let me know.
As simple as this sounds…random stops is usually a Bad SD Card…so try using another card.
Wait, what? So you say, because I was doing time-lapse recording, the extrusion just stopped because the time-lapse could not be written to the sd-card because of what ever issue the sd-cards has? Is it that what you are trying to tell me?
Do I understand that correctly?
This seems to be too simple but sort of maybe makes sense. What I do not understand ist, that the SD-Card is linked to the extruder. Everything else was still working normal. Movement, x-y-z axis. It was just that the extruder stopped extruding filament and the AMS was not pushing.
I will try again without auto-monitoring and without time laps. then I will get a new sd-card. Still using the original one but will replace with a good Samsung Evo.
Thanks for the hint as this would probably be the last I could think of.
If that doesn’t work, then for diagnostic purposes it should be easy enough to switch to a different brand of filament just to see if that by itself clears the problem. It should be easier to do that than to search for a fatal flaw in the filament that’s already mounted.
Also, you didn’t mention layer height, but if layer height is too short, it could conceivably produce the effect you described.
Sorry, you are right, forgot to mention the layer height. I was printing the standard 0.2mm Profile from within BBL Studio.
If the stupid filament still does not work, turned off time-lapse and auto-monitoring, I will try printing with another PETG/PLA filament.
Update: After chaning the SD-Card and formatting it through the printers menu, everything seems to work fine. The solution probably was a failing SD-Card. What a strange thing that this is not handled by the printers OS in a better way.
