Filament stuck in the nozzle holder
As you can see in the first photo the nozzle is kinda sideways , i think its because of the filament that dripped into the back of the nozzle holder
The filament in question
Cant put the nozzle correctly and it does not heat up
A1 mini
The filament is like a champagne color , its pla
Have you removed the hot end and cleaned out the filament from behind there?
I have tried but i cant (or dont know how ) to remove the part that has the filament , the hot end is not where the plastic is
Hit it with a blow dryer. Just don’t go nuts because it’ll get hot enough to melt other stuff if you’re not careful. Heat the plastic up enough to soften it and you may be able to get everything apart for a more thorough cleanup/repair…
