Filement being wierd
ok so when i print the filament is almost like stuck under another piece like it pulls the filament and then tightens into like a cris cros pattern and then i have to keep watching it to release the tension and allow it to pull the filament hard to explain and it only hapes like half way thu the role
if anybody could help also need help with what to print i am in the spot where i am stuck on what to make and have just been scrolling maker world in hope i find something of use
another weird question i have an old old 3d printer anybody know of a way to make it into a filament recycler to recycle failed prints and the extrusion waist
Your filament is tangled. At some point the loose end got under another piece. It might be 3,4,5, or 6 wraps back. You have to unwind it until you can pull it out from under the other piece and then roll it back up. Sometimes you can just look at the filament and see where it crosses under and then grab it at that point and pull on it.
Dude!!! Take a deep breath and switch to decaf, you’re all over the place.
Let’s see if we can help.
In the subject of filament acting unexpectedly. It doesn’t matter how colorful your description is, a picture would go a long way. You’ll find more people willing to respond to something they can see than trying to makes sense of a description.
On the subject of what to print? Are you serious? You need advice? Print a Benchy for crying out loud if you can’t figure out what to print.
On the third question. There are tons of YouTube videos on how to create a filament extruder using parts from a decommissioned printer. Now here’s the crazy part, none of them are worth the time and effort if your goal is to save time and money, these are simply curiosity pieces. Consider this, all the solutions require grinding scrap prints into tiny bits and then melting before they reach the nozzle. The best rate I saw was one 1KG spool over 3 hours time. Given that filament can be found of $10/spool, that means you’re saving $3/hour. Unless you’ve got nothing better to do, it is an ideal way to waste time and money. But it can be fun if you’re into tinkering.
