Firmware 1.09 - Can't change filament settings
Just upgraded to 1.09 and then changed filament… No matter what I do, I can’t change the type or colour of filament using the UI.
For example if I change from White to Red and hit “confirm” the colour stays the same and if I “edit” the slot, its like I haven’t done anything
Same if I go from PETG to PLA… Again, ‘confirm’ and nothing happens.
I did manage to change it once, but I don’t know what I did… And now I have Red PETG ‘stuck’ in one of my bays…
This is a bit of a deal breaker is it not? Anyone else seen this?
Ignore this… Its just a bit slow… You have to wait 3-5 seconds before it updates… If you don’t wait and ‘edit’ the slot again, the settings havn’t changed.
I would delete this, but figured someone else might spot it, so left it here with the answer.
Také nemohu změnit filament v zařízení.Nastavim ASA a změní se zpět na PetG.
