Firmware Update 1.1.0.0 fails [solved]
After downloading 32-46% the A1 reboots but does not update to fw 1.1.0.0.
Does anyone else has the same problem?
One hour later I had success.
So edit the post please
I can mark it as solved, but I don’t find any option to delete the post.
The trash symbol doesn’t work. “You don’t have permission to delete this topic.”
I asked an admin to delete it …
Ignore him. He is a weirdo in this forum Lol
I have totally the same problem.
Update to 1.0.0.1 OK.
Update to 1.1.0.0 failed.
I tried complete reset but it did not help. :man_shrugging:
Damn… 2 days I was unable to update the firmware and after my previous comment the update successfully completed… :man_facepalming:
I had the same issue and I am still unable to update. Strange.
5 minutes after i wrote this IT finally worked Tip for all Who habe the Same Problem use Bambu Studio on your Computer to update
I still have this problem and am working with bambu support but so far nothing they’ve said has worked. Mine stops on the display at 25% then reboots.
If I initiate via the mobile or desktop app it gets to 45% and reboots.
Have tried every day so far for week, hopefully there is a fix soon.
Try removing or changing the SD card.
I randomly popped in an unformatted 128GB card, hit the format button, but it didn’t seem to do anything. Then I hit update and it successfully downloaded and updated.
[SOLUTION]
My A1 was having this issue: came in out the box with 01.02.00.06 firmware, tried to update to 01.03.00.00, would fail @ 31/32%.
“downgraded” to 01.02.02.00 - succeeded, then 01.03.00.00 - succeeded.
hope it works/helps.
  • Hepaestian
I had same issue where it stopped at 32 and failed.
I tried 1 02.02.0 and it worked but latest failed at 32 again
I eventually updates to latest via the peibter and it worked.
