Yeah that makes a lot of sense.
I already have the room around 30c so it shouldnt be hard to get it up a bit. I only have it at 50 and still getting corner lifts with brim…will try that one
Cheers
Yeah a 4+ is def on the way and then will get rid of the x1…after its dialed in…
BTW I just heated up a pot of water…it was just those purple non toxic sticks…they dissolve but takes a little while
I think part of my problem is using non-Bambu PLA (currently trying Printerior recycled PLA).
I have some 1st layer problems, and problems with layers splitting off.
I am wondering if room temp matters, and if a little table wobble matters.
So am curious what your room and table are like to print so well?
Are you positive the filament is dry? I run all types of filaments and brands. From the cheapest to the more expensive. Never found a difference based on table.
For all those still looking for an answer. What seemed to work for me was raising the nozzle (.05). so instead of the stock .20 (standard). Manually change it to (.25) for the first layer in the settings.
