First layer inspection always throws an error
After my first layer which is fine. The printer is asking me to verify and continue. It stops with an error message and just wait for me to respond. It’s doing this 95% of the time. Different colours you ask? Same behaviour
If you use the Textured Plate it’s normal.
Well, no, if you use the textured plate it skips the first-layer inspection and puts up a message saying so, but the print continues.
I am using the PLA plate “cool plate”
do you use additional light? the lidar can get confused with to many light
Hi everyone!
I’ve had a Bambu Lab A1 with AMS for 4 months, and it has been in continuous use. I always lubricate the axes and clean the build plate regularly.
However, lately, along with a few other errors, a new one has appeared, as shown in the picture below.
Whenever this error occurs, the print quality of the affected layer is really poor. I’ve already removed the hotend, unscrewed it, and reinstalled it. The printer went back to printing normally, but shortly afterwards, the same error appeared again.
Has anyone experienced this issue before? Could you help me figure out what might be causing it and what I can do to fix it?
Thanks in advance!
