Hello,
as you can see from the photos, the line at the top right of the pressure plate, which is used among other things to clean the nozzle tip, has not been placed correctly. The pressure plate was placed correctly so that it touches the rear reference points so that the plate sits correctly. I also enabled the “Enable plate position detection” print option.
Can anyone help me?
Also check if the nozzle is bent.
