Flow drop right after bottom layer
Yeah exactly what I found after some extended research.So I finally got an answer to the physical part of it. Its also a well known problem that since vase mode is integrated in all the slicers theres a bug that you cant use a modifier with it. No slicer dev seems to want to fix this issue.
And you are right, using boolean does cut the hole. Havent seen it til I sliced a preview.
I stumbled over another thread where the OP found a workaround for using modifiers while vase printing. I wasnt been able to recreate it but I will give it a go again today.
https://forum.bambulab.com/t/change-wall-thickness-in-vase-mode/83836/10
