I have done my K Value, do l need to untick Flow Dynamic Calibration at the start of a print or leave it enabled to work long side my k value inputted into Bambu Studio?
Thanks
Thanks
I have the same question :o
I don’t think they are related, I think Flow Dynamic is volumetric flow.
Again though, Im not 100% sure, so I leave it ticked even after doing K value ![]()
I don’t know exactly how it is implemented but I think of it like this:
The auto flow dynamics is for when you have not calibrated filament. If you take the time to manually calibrate the K [PA] and Flow Ratio then you have dialed in anything the automatic would account for so I turn that off, it can only change my perfectly calibrated values possibly based on a bad lidar reading.
Just make sure your manually calibrated values are in use, K on the device tab in the filament view and flow ratio on the selected filament profile.
K on the device tab, filament view:
Filament profile:
I spent a day calibrating my filaments, flow and k value, I’ll disable the auto flow and print a model and see how it looks, thanks for your reply.
I thought you kept it ticked at all times ![]()
