Flow Rate Calibration 2nd step always prints pieces from 0 to -9
I am in Bambu Studio 2.5.0.66 on Linux. I am using a 3DJake silver PCTG filament with not so optimal results. Through the Bambu Studio Training Courses I learned about he filament calibration. Run first level. Checked the printed pieces and decided that part “5” is the best. Run fine calibration, but instead of printing 0 to +9, it printed 0 to -9.
Today I went there again. Selected “Fine Callibration based on flow rate”, changed the already entered “0.95” to “1.05” (since my best piece was “5” and not “-5”) and again it printed pieces from 0 to -9.
The json file that it has created under “/.config/BambuStudio/user/XXXX/filament/3DJake PCTG Flow Rate Calibrated.json look like this:
    "filament_extruder_variant": [
        "Direct Drive Standard",
        "Direct Drive High Flow"
    "filament_flow_ratio": [
        "0.9765",
        "nil"
    "filament_settings_id": [
        "3DJake PCTG Flow Rate Calibrated"
    "from": "User",
    "inherits": "Generic PCTG @BBL P2S",
    "name": "3DJake PCTG Flow Rate Calibrated",
    "version": "2.5.0.14"
Did anyone also run into this? Any tips?
I think it has been 0 to -9 since I can remember. Why should it be 0 to +9?
I don’t understand why it isn’t -5 to +5. That would make more sense to me than both of those options.
0 to +9 or 0 to -9 doesn’t matter; the test designer had to choose one direction before creating the second-pass test. If the optimal result is at +7, testing +5 to -5 would not find it.
The first pass only narrows the testing range. Then the second pass tests flow rates in smaller steps in a range between too high and too low.
I don’t choose the best result from the first pass. I choose the first result higher than the smoothest, the one that is clearly over-extruded. Then the second pass reduces flow in small steps to test between slightly too much flow and slightly too little.
I made a simple spreadsheet to help me see how my choice affects the rates to be tested. Changing the yellow cells updates the rates to be tested.
Rename to remove the “.3mf” extension.
Flow calibration calculator.xlsx.3mf (7.5 KB)
I don’t think using the third decimal place makes a significant difference in flow, but I don’t round it; I keep it because it indicates that it is a calibrated flow rate.
I usually delete some samples before printing the first pass. Starting with a Generic profile, I’ve never had a filament that produced a good result at ±20, or even ±15.
Thanks a lot for sharing this. I’ll retry it. When using the flow from BambuStudio it sends directly to the printer, without letting me edit the samples.
Enable Develop mode in Preferences to enable the manual Calibration menu at the top of Studio.
Then, unneeded samples can be deleted.
