Flow Rate Calibration for First Layer
I’ve got some problems printing the first Layer without gaps on the PEI-Plate.
It’s getting better when I change the print Temperatur for the first layer 10 C° up and change the first layer line width from 0,5 to 0,42 , but it’s still not perfect.
It would be nice if it would be possible to change the Flow-Rate for the First-Layer.
please try the following
Elephant Foot Compensation = 0.2mm
This doesn’t work for me.
this doesn’t affect the flow rate, it just downscales the xy axis
Use BambuStudio-SoftFever, here you can change the flow rate for the first layer, or maybe the filament is not calibrating itself quite correctly and let’s see how the flow in the filament profile is, maybe set the extrusion factor to 1 or 1.05 there
