I’m doing a flow rate calibration. I finished step 1 of calibration and now i have plate of seemingly identical test models and I can’t decide which is the best result
I’m absolutely terrible in telling such tiny details apart.
Next, I’d recommend running the second, more precise calibration using a value of 1.100. You may need to enter that value manually.
Why 1.100? Because the second, finer calibration only tests values below the selected starting point, not above it. This way, you’ll cover all the values below 1.1.
One more tip: Mix up the plates, close your eyes, and feel which ones are the smoothest. Pick the three smoothest ones without looking, then check their values. You can also try running your fingernail lightly across the surface to feel the differences.
If you can’t see the difference, the textures feel noticable different when scraped with a fingernail. Advanced users can use their tongues if they are suitably brave or foolish (edit because of microplastic and fibre reinforced filament).
They amplify any over or under extrusion and so allow much easier identification of the correct flow rate. Even with increments of 0.005, I feel confident to decide the right one.
Under-extrusion is when there is air between the lines. Like a dry river between the plains. Over-extrusion is the opposite: mountains form, but there are no air gaps. You often can’t see the difference very clearly, and the numbers can influence your judgment. That’s why I think a blind test is the best approach.
Under-extrusion: It looks like filament line, air gap line, filament line, air gap line
Much more clear with the example pictures in addition to your words. I was concerned that over just created one line higher than the other. The opposite of the under. Stating mountains and seeing the slight bubbling helps. It is not meant to be perfect lines as well.
