Flush to Object could be better
I made a video about this, but maybe it’ll get some more traction here. In Bambu Studio you can set objects to be flush objects, and it will reduce the amount of purge waste created, but it only works for the first two colors, and it doesn’t stop purging to the purge objects if you if it purges enough, meaning it might over purge to the objects, and the, again, it doesn’t purge the 3rd and 4th colors to the object at all. It’s functional, but it could be way better if Bambu would put a little time into it.
Would you like to see this feature to better use the AMS?
Totally agree, coming from the Prusa Side and seeing how they have implemented the wipe tower and purge to infill with no additional “poop” waste, I really hope they upgrade the level of efficiency in waste on the PiS side.
The waste is an annoying necessity. I would like to see them add a “Flush by object” feature that combines ‘flush into this object’ with ‘print by object.’
As a default all flush into objects would become an individual ‘flush object’ completed by layer and everything else would be a ‘Main object’ also completed by layer. Resume the print progress of the ‘flush object’ each time a flush is needed and Resume the print progress of the "Main object’ once the flush is completed.
This would be a significant improvement over the current feature only utilizing print volume of flush objects at same layer height.
Yes pugre into object would be better.
I suggest an idea in github:
issues/4476
What would be great, should be that in bambu studio, a prompt that select and show basic object list automaticly from your store that would fit, and resize it to optimise the maximum of purge in it.
