Foam board cutting with the H2D laser?
Good day to all,
I’m curious if it’s possible to cut rubber/plastic foam board with the H2D’s laser, and if so what thickness of foam board you can cut at most. Does anyone have experience?
Specifically I would be most interested in using it to make shadowboard-style individualized cutout shapes for tools and measuring instruments, I believe PE foam is the standard for this. If the H2’s laser somehow isn’t fit for that material do tell if there’s another material that’s suitable.
The only value you readily find for cutting depth is 5mm of plywood with the 10W and 15mm with the 40W. Are there more elaborate tables of reachable depths for all sorts of other materials, and which ones don’t work at all?
Yes — the H2D 455 nm blue diode laser handles tool shadowboard inserts really well as long as you pick the right foam chemistry:
  1. Material choice (critical for both cut quality and machine safety):
    • Avoid PVC / vinyl foam completely — chlorine gas from PVC will corrode the H2D linear rails and optics in a single session.
    • Dark charcoal/black closed-cell EVA foam (EVA38 or EVA45 density) cuts far cleaner on a 455 nm diode laser than white or light-colored cross-linked PE (XLPE / Kaizen). Blue 455 nm light scatters inside white PE and leaves wide melted bevels, whereas black closed-cell EVA absorbs 455 nm cleanly with crisp vertical walls.
  2. Practical thickness & pass limits:
    • 10W module: Clean single-pass cuts on 5–10 mm black EVA (~650–800 mm/min, 85–90% power, air assist ON).
    • 40W module: Can step through 15–25 mm black EVA in 2–3 Z-stepped passes without heavy top-edge char if you keep speeds up and let air assist clear the kerf.
  3. CAD layout tips for calipers & hand tools:
    • Offset tool outlines outward by ~0.18–0.22 mm to compensate for thermal melt kerf so micrometers/calipers press-fit snugly instead of rattling.
    • Keep at least 8 mm foam ribs between adjacent tool pockets so walls don’t tear out, and add 18 mm semicircular finger-pull notches on flush-seated gauges.
(Full disclosure: I built a small browser tool for my own shop) If you want 1:1 tool outlines without a flatbed scanner or manual spline tracing in Fusion, you can drop your calipers or pliers on a standard A4 or US Letter sheet and run a top-down phone photo through FoamKerf — it rectifies camera tilt into a 1:1 kerf-compensated DXF/SVG (or a rigid 3D-printable STL if you ever want a hard PETG drawer insert instead).
