Font? Where can I change the Font?
Where can I change the Font? I don’t use a Standard Windows 10 Font, nor do I have “ClearType” Enabled. So There is a huge Problem with the Font in Bambu Studio and OrcaSclicer. The Font is fuzzy and very hard to read for me.
The Font in the menu bar is good and clear, but the rest isn’t.
In Cura, there is a Folder, where I can set a Font and text size. But this does not work here… any ideas?
Right click on the program shortcut and open properties. Then play around with the DPI options on the compatibility tab. One of them should fix it.
Solved by enabling Clear Type in Windows (7)
Yeah, but I dont enbale ClearType for a slicer. I hate ClearType - thats why its disabled.
An in my opinion, its stupid when a program use a dedicated font - in this case HarmonyOS from Huawei
What’s the downside to using ClearType?
If a solution is stupid but it works, it’s not stupid.
I dont use SegoeUI as the default system font. And ClearType makes SegoeUI fuzzy.
I need a font with clear edges, Tahoma without ClearType is a razer sharp font.
If you need your own unique font, you can create it in Creative Fabrica Font Generator and try downloading it.
