I have to start with I searched high and low in Wiki for information
then contacted BL who have only provide generic answers so far.![]()
After successfully completing an hour print over night, I was unable to print anything. I had a message that the filament could not be loaded. I could see the filament moving from my AMS to the FTS to the RHS print head, so I assumed it was blocked. when I looked closer the hot end looked a mess (see picture) - following Wiki the subject hot end could not release. I followed the next step to remove the grey plastic cover, it seemed welded in place - high temps had fused parts of the assembly. Forcing it out, caused a wire in the fixed head (I didn’t know about) it’s not in Wiki to break.
I’m now waiting for BB to replace my unit under the warranty I purchased - since to me it needs a complete new printhead. However, the picture shows some things that look strange to me.
I suspect if you have an H2C and have ever changed the 2 print heads you know the answers, so here is my situation.
Email sent today to BL..
I saw your reply confirming my H2C would be replaced by BestBuy and passing on my comments to your technical writers.
However, this does not address the concerns I listed below:
I have marked in yellow the subject wire that goes into the LHS or fixed head.
- How do I remove the print head to change size if a wire is inserted into the cool section?
- This is completely missed in any Wiki information I can find. All information show NO wires to the cool end.
- Should it just pull out or??
- I have also indicated in yellow (RHS) a forked blade device that seemingly holds the RHS “removable” printhead in place.
It was very difficult to move (seized) but when I finally got it out the removable head released and dropped – this device
doesn’t want to go back.
Does this get moved by the Vortec system or what function other does it have?
Again, it’s not shown in Wiki pictures or videos for H2C
Would you please my questions directly, rather than have me look out for future modifications to Wiki.
John C
Sent: Thursday, November 26, 2026 1:37 PM
To: ‘support@service.bambulab.com’ support@service.bambulab.com
Subject: RE: Your ticket has a new reply:TECH_Hotend or PrintTool Automatic Fetch/Place Failure_US_US261125928002_WEB_2606
Hi,
You have the situation partly correct, but as normal have not addressed the specific issues.
The scripts in Wiki do not address the specific H2C that I have.
The link you provided is not for specifically for H2C and actually contains another link purporting it’s for H2C. See the pasted picture below. However, it still doesn’t reflect my unit – you should look up the serial number to see why.
Let me again step you thru the issues.
- The exchangeable hot end release did not work even after putting it thru a heating cycle.
- It would not pull out even using pliers, it seems to be fused into the mechanism.
- I have no idea how long the Vortec system has not been able to exchange heads
- The fixed head can also not be removed as you show since there was an unseen wire passing through the grey plastic cover (remove with 3 screws) into the head.
- The picture / video you have showing the fixed head being removed doesn’t address this wire.
- The same wire first passes thru the plastic cover and when I was finally able to remove it, that broke the wire from the print head. Part of it remains in the head, my spare hot end just has a hole in the top how it the wire to be fixed or removed.
- You mix up details for H2D and H2C.
- You need to have a complete description of the H2C as no doubt you will for H3C
It seems to me that multiple automatic attempts to unblock the blocked hot end using the heating method in Wiki, had fused the complete assembly, especially including the plastic sections and exchangeable hot end. I would have no confidence in doing anything but a complete Printhead replacement.
I’m a retired engineer, I’m used to writing, reading and following instructions. I appreciate you have many different models, but it should not be beyond your capabilities to correctly link scripts and pictures for specific models.
This reply is to try and get you to improve your information for different models – In my case, since I purchased a 4 year warranty they are replacing this 6month old unit entirely.
John C
From: support@service.bambulab.com <support@service.bambulab.com>
Sent: Wednesday, November 25, 2026 9:45 PM
To: britgeezer@hotmail.com
Subject: Your ticket has a new reply:TECH_Hotend or PrintTool Automatic Fetch/Place Failure_US_US261125928002_WEB_2606
2026-11-26 10:40:55
Dear Customer ,
Thank you for contacting Bambu Lab Customer Suppor t.
We are sorry to hear that you are experiencing this issue, and we apologize for the inconvenience caused. Based on the information you provided, both the Hotend Heating Assembly - Left and the Induction Hotend Heating Assembly appear to be stuck and cannot be disassembled. From your description, it seems that a cable may have broken — could you please confirm whether it is the connection cable of the Hotend Heating Assembly? Judging from the photos you provided, the Hotend Heating Assembly - Left should be removable; for specific instructions, please refer to this wiki: [Replace H2D/H2C Hotend Heating Assembly | Bambu Lab Wiki ].
Regarding the Induction Hotend Heating Assembly, please set the nozzle temperature and check whether it heats up normally, and share the results with us. In addition, please provide us with more clear photos or a video so that we can further understand the extent of the dam age.
Please also provide the following information so that we can register the after-sales service for you:
