X1C without AMS, and I’m suddenly getting frequent filament runout pauses. Current print is less than one hour in, and it’s come up 4 times already. I need only to tell it to resume, and it picks up and goes on, so it for sure is not actually run out. I don’t even go to adjust filament, just tell it to go again, and it does. I’ve used different spools and it’s been the same. Single color print obviously since it is without AMS. No pauses in the job intentionally.
Check the wire connections. Sounds like a loose connection.
Looks like the little clear bit on the print head? I’ve certainly had to take that off enough times to unclog. Guessing it might be the connector back to the main board on the head?
Here is a link to the wiki article
I’d guess this is it. Much appreciated. Was thinking it was prior to the print head for some reason, but that wouldn’t make sense the more I think about it.
