From Inkscape to Bambu Studio
I create images in Inkscape with multiple colors/levels and want to put them into Bambu Studio to print with AMS, but the images never line up correctly. Here are my steps…
  1. separate image into colors/levels in Inkscape
  2. export each color/level as a seperate svg
  3. Drag all images into Bambu studio. and this is where all the images go in but do not allign the same as in inkscape
How do i get these images to align? I used to go from inkscape to tinkercad to bambu studio and it worked fine. But lately the items are too complex for tinkercad and it wont even load the file.
Have you tried the makerworld keychain app? It converts png files into 3mf based in colors available.
that is a very good solution, I went from inkscape to get what I want, to the keychain app, and it seems to work out well. I would still love a solution to that is less steps, straight from inkscape to bambu studio.
As sometimes I want 5 colors, a base, I can pause, change out colors and then print the main 4 on top of that
Did you right-click on the build plate in Bambu Studio and select “Add Primitive” then choose SVG? My image came all together but I’m having issues painting it…I did something wrong in Inkscape I bet.
I used file import Svg. Is there a different?
