Hi. Iām new to trying scripts in Bambu. Should the fuzzification show up in the preview? Iām using Bambu Studio 1.10.2.76 with an X1E.
No, I donāt think so. Itās a post-processing script, the slicer doesnāt āknowā the modifications have been made.
If the slicer could directly open a G-Code file, youād see it. But I donāt think the slicer can do that.
However, if you do a Google for āG-Code Viewerā youāll find a wide assortment of options that will āseeā the modified fuzzy skin if you load the G-Code file generated by the Fuzzification script.
You can āreplaceā the gcode in a .gcode.3mf file and it should show it. Iām pretty sure a script could be setup to do this automatically.
Reference:
Thanks. I exported & reloaded the gcode into Bambu Studio, and there it was! Printed a test piece and it worked, just playing with the values now to get the walls & top looking similar. Many thanks for the quick responses.
Iām trying to get fuzzificator to work with my Bambu P2S. I run Bambu studio on a Mac. Iām trying to print from Fusion 360.
I copy the path into the post processing field in other in Bambu Studio and when I go to preview, I get the message below.
I donāt know Python at all, so Iām kind of lost.
Iād sure appreciate any help.
Post-processing script /Library/Frameworks/Python.framework/Versions/3.14/bin/python3 /users/Ctt/Documents/Scripts/Fuzzyficator_Bambustudio.py.html on file
/var/folders/hv/rhg_fz2d7217ts9fx69plysw0000gn/T/bamboo_model/Thu_Feb_12/19_53_42#5184#7/Metadata/.5184.0.gcode failed.
Error code: 1
Output:
File ā/users/charlesthompson/Documents/Scripts/Fuzzyficator_Bambustudio.py.htmlā, line 134 Fuzzyficator/Archive/Bambustudio/Fuzzyficator_Bambustudio.py at main ⢠TengerTechnologies/Fuzzyficator ā¢
GitHub
SyntaxError: invalid character āā¢ā (U+00B7)
After some tinkering, I discovered the Python author has a more recent version. I downloaded that and to worked, but the surfaces arenāt as rough as Iād like.
If anyone has tinkered with this, Iād appreciate any insight to using the variables.
I have played with this a bit. For example I like Fuzzy Skin parameters 0.2mm and 0.2mm. It gives a texture similar to Textured PEI plate.
But when Fuzzificator picks up these parameters the result is like sandpaper. And infill lines are still kind of visible. I have a feeling that fuzzySpeed argument is required to print slower.
Also Iām not a big fan of printer bed shaking to get this effect. Will probably not use it anymore unless someone finds good settings.
