FYI: Time lapse and print speed
If you are not actually trying to capture a time lapse video you might want to turn off time lapse.
Time lapse looks so good because it moves the print head out of the way. This is going to affect the speed of printing.
I can’t translate the gcode for layer changes accurately because there are custom Bambu gcode instructions, but you can see code that runs for time lapse both with and without the wipe tower.
I believe timelapse only affects the speed of the printing if you select “smooth”, otherwise it takes a snapshot once for each layer, regardless of where the toolhead is.
