Short version: how do I change the gcode to lower the nozzle temperature to 140° during bed leveling?
Long version: The only g code modifying i have done is adding the pause code to filament to allow changing colors mid layer, so you might say I’m a professional…oh no…I mean a novice that has almost no idea what they are doing and will absolutely screw something up.
I bought a wham bam carbon fiber plate, it’s recommended that the nozzle temp be no higher than 140°c during bed leveling, or it can damage the plate. I was smart enough to check on the A1 what the temperature it levels the bed at. It was doing it at 220°c, that’s not ideal.
Can someone please explain it like I’m 5 on how to change the gcode to lower the nozzle temp during bed leveling? Will this have any impact on the bed leveling results? Does Bambu heat up the nozzle to printing temps so early just so there is less down time while the nozzle heats up?
Yes, I’m clearly in over my head, but how else do you learn unless you try?
