Gcode for test print that just homes and then moves Z
Im trying to make a test print that just homes my P1S and then moves to z220, so I can use it to test a automation project Im working on, Im struggling to get the gcode to work correctly though.
right now it seems to do a whole lot of nothing, it just jumps to being done with no movement, I am putting this code into plate_1 on a 3mf file.
what am I missing? I just want it to be the bare minimum so machine doesn’t crash and just homes and moves Z
code
; HEADER_BLOCK_START
; BambuStudio 01.07.07.89
; model printing time: 1h 10m 50s; total estimated time: 1h 16m 38s
; total layer number: 378
; model label id: 99
; HEADER_BLOCK_END
; CONFIG_BLOCK_START
; accel_to_decel_enable = 0
; accel_to_decel_factor = 50%
; activate_air_filtration = 0
; additional_cooling_fan_speed = 70
; auxiliary_fan = 1
; bed_custom_model =
; bed_custom_texture =
; bed_exclude_area = 0x0,18x0,18x28,0x28
; before_layer_change_gcode =
; best_object_pos = 0.5,0.5
; bottom_shell_layers = 3
; bottom_shell_thickness = 0
; bottom_surface_pattern = monotonic
; bridge_angle = 0
; bridge_flow = 1
; bridge_no_support = 0
; bridge_speed = 50
; brim_object_gap = 0.1
; brim_type = auto_brim
; brim_width = 5
; chamber_temperatures = 0
; change_filament_gcode = M620 S[next_extruder]A\nM204 S9000\n{if toolchange_count > 1 && (z_hop_types[current_extruder] == 0 || z_hop_types[current_extruder] == 3)}\nG17\nG2 Z{z_after_toolchange + 0.4} I0.86 J0.86 P1 F10000 ; spiral lift a little from second lift\n{endif}\nG1 Z{max_layer_z + 3.0} F1200\n\nG1 X70 F21000\nG1 Y245\nG1 Y265 F3000\nM400\nM106 P1 S0\nM106 P2 S0\n{if old_filament_temp > 142 && next_extruder < 255}\nM104 S[old_filament_temp]\n{endif}\nG1 X90 F3000\nG1 Y255 F4000\nG1 X100 F5000\nG1 X120 F15000\n\nG1 X20 Y50 F21000\nG1 Y-3\n{if toolchange_count == 2}\n; get travel path for change filament\nM620.1 X[travel_point_1_x] Y[travel_point_1_y] F21000 P0\nM620.1 X[travel_point_2_x] Y[travel_point_2_y] F21000 P1\nM620.1 X[travel_point_3_x] Y[travel_point_3_y] F21000 P2\n{endif}\nM620.1 E F[old_filament_e_feedrate] T{nozzle_temperature_range_high[previous_extruder]}\nT[next_extruder]\nM620.1 E F[new_filament_e_feedrate] T{nozzle_temperature_range_high[next_extruder]}\n\n{if next_extruder < 255}\nM400\n\nG92 E0\n{if flush_length_1 > 1}\n; FLUSH_START\n; always use highest temperature to flush\nM400\nM109 S[nozzle_temperature_range_high]\n{if flush_length_1 > 23.7}\nG1 E23.7 F{old_filament_e_feedrate} ; do not need pulsatile flushing for start part\nG1 E{(flush_length_1 - 23.7) * 0.02} F50\nG1 E{(flush_length_1 - 23.7) * 0.23} F{old_filament_e_feedrate}\nG1 E{(flush_length_1 - 23.7) * 0.02} F50\nG1 E{(flush_length_1 - 23.7) * 0.23} F{new_filament_e_feedrate}\nG1 E{(flush_length_1 - 23.7) * 0.02} F50\nG1 E{(flush_length_1 - 23.7) * 0.23} F{new_filament_e_feedrate}\nG1 E{(flush_length_1 - 23.7) * 0.02} F50\nG1 E{(flush_length_1 - 23.7) * 0.23} F{new_filament_e_feedrate}\n{else}\nG1 E{flush_length_1} F{old_filament_e_feedrate}\n{endif}\n; FLUSH_END\nG1 E-[old_retract_length_toolchange] F1800\nG1 E[old_retract_length_toolchange] F300\n{endif}\n\n{if flush_length_2 > 1}\n; FLUSH_START\nG1 E{flush_length_2 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_2 * 0.02} F50\nG1 E{flush_length_2 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_2 * 0.02} F50\nG1 E{flush_length_2 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_2 * 0.02} F50\nG1 E{flush_length_2 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_2 * 0.02} F50\nG1 E{flush_length_2 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_2 * 0.02} F50\n; FLUSH_END\nG1 E-[new_retract_length_toolchange] F1800\nG1 E[new_retract_length_toolchange] F300\n{endif}\n\n{if flush_length_3 > 1}\n; FLUSH_START\nG1 E{flush_length_3 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_3 * 0.02} F50\nG1 E{flush_length_3 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_3 * 0.02} F50\nG1 E{flush_length_3 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_3 * 0.02} F50\nG1 E{flush_length_3 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_3 * 0.02} F50\nG1 E{flush_length_3 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_3 * 0.02} F50\n; FLUSH_END\nG1 E-[new_retract_length_toolchange] F1800\nG1 E[new_retract_length_toolchange] F300\n{endif}\n\n{if flush_length_4 > 1}\n; FLUSH_START\nG1 E{flush_length_4 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_4 * 0.02} F50\nG1 E{flush_length_4 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_4 * 0.02} F50\nG1 E{flush_length_4 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_4 * 0.02} F50\nG1 E{flush_length_4 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_4 * 0.02} F50\nG1 E{flush_length_4 * 0.18} F{new_filament_e_feedrate}\nG1 E{flush_length_4 * 0.02} F50\n; FLUSH_END\n{endif}\n; FLUSH_START\nM400\nM109 S[new_filament_temp]\nG1 E2 F{new_filament_e_feedrate} ;Compensate for filament spillage during waiting temperature\n; FLUSH_END\nM400\nG92 E0\nG1 E-[new_retract_length_toolchange] F1800\nM106 P1 S255\nM400 S3\nG1 X80 F15000\nG1 X60 F15000\nG1 X80 F15000\nG1 X60 F15000; shake to put down garbage\n\nG1 X70 F5000\nG1 X90 F3000\nG1 Y255 F4000\nG1 X100 F5000\nG1 Y265 F5000\nG1 X70 F10000\nG1 X100 F5000\nG1 X70 F10000\nG1 X100 F5000\nG1 X165 F15000; wipe and shake\nG1 Y256 ; move Y to aside, prevent collision\nM400\nG1 Z{max_layer_z + 3.0} F3000\n{if layer_z <= (initial_layer_print_height + 0.001)}\nM204 S[initial_layer_acceleration]\n{else}\nM204 S[default_acceleration]\n{endif}\n{else}\nG1 X[x_after_toolchange] Y[y_after_toolchange] Z[z_after_toolchange] F12000\n{endif}\nM621 S[next_extruder]A
; close_fan_the_first_x_layers = 1
; complete_print_exhaust_fan_speed = 70
; cool_plate_temp = 35
; cool_plate_temp_initial_layer = 35
; curr_bed_type = Textured PEI Plate
; default_acceleration = 10000
; default_filament_colour = ""
; default_filament_profile = "Bambu PLA Basic @BBL X1C"
; default_jerk = 0
; default_print_profile = 0.20mm Standard @BBL X1C
; deretraction_speed = 30
; detect_narrow_internal_solid_infill = 1
; detect_overhang_wall = 1
; detect_thin_wall = 0
; different_settings_to_system = sparse_infill_density;;machine_end_gcode;printable_height
; draft_shield = disabled
; during_print_exhaust_fan_speed = 70
; elefant_foot_compensation = 0.15
; enable_arc_fitting = 1
; enable_overhang_bridge_fan = 1
; enable_overhang_speed = 1
; enable_pressure_advance = 0
; enable_prime_tower = 0
; enable_support = 0
; enforce_support_layers = 0
; eng_plate_temp = 0
; eng_plate_temp_initial_layer = 0
; ensure_vertical_shell_thickness = 1
; exclude_object = 1
; extruder_clearance_height_to_lid = 90
; extruder_clearance_height_to_rod = 36
; extruder_clearance_max_radius = 68
; extruder_clearance_radius = 57
; extruder_colour = #018001
; extruder_offset = 0x2
; extruder_type = DirectDrive
; fan_cooling_layer_time = 100
; fan_max_speed = 100
; fan_min_speed = 100
; filament_colour = #898989
; filament_cost = 20
; filament_density = 1.24
; filament_diameter = 1.75
; filament_end_gcode = "; filament end gcode \nM106 P3 S0\n"
; filament_flow_ratio = 0.98
; filament_ids = GFL99
; filament_is_support = 0
; filament_max_volumetric_speed = 12
; filament_minimal_purge_on_wipe_tower = 15
; filament_settings_id = "Generic PLA"
; filament_soluble = 0
; filament_start_gcode = "; filament start gcode\n{if  (bed_temperature[current_extruder] >55)||(bed_temperature_initial_layer[current_extruder] >55)}M106 P3 S200\n{elsif(bed_temperature[current_extruder] >50)||(bed_temperature_initial_layer[current_extruder] >50)}M106 P3 S150\n{elsif(bed_temperature[current_extruder] >45)||(bed_temperature_initial_layer[current_extruder] >45)}M106 P3 S50\n{endif}\n\n{if activate_air_filtration[current_extruder] && support_air_filtration}\nM106 P3 S{during_print_exhaust_fan_speed_num[current_extruder]} \n{endif}"
; filament_type = PLA
; filament_vendor = Generic
; filename_format = {input_filename_base}_{filament_type[0]}_{print_time}.gcode
; filter_out_gap_fill = 0
; first_layer_print_sequence = 0
; flush_into_infill = 0
; flush_into_objects = 0
; flush_into_support = 1
; flush_multiplier = 1
; flush_volumes_matrix = 0
; flush_volumes_vector = 140,140
; full_fan_speed_layer = 0
; fuzzy_skin = none
; fuzzy_skin_point_distance = 0.8
; fuzzy_skin_thickness = 0.3
; gap_infill_speed = 250
; gcode_add_line_number = 0
; gcode_flavor = marlin
; host_type = octoprint
; hot_plate_temp = 55
; hot_plate_temp_initial_layer = 55
; independent_support_layer_height = 1
; infill_combination = 0
; infill_direction = 45
; infill_jerk = 9
; infill_wall_overlap = 15%
; inherits_group = ;;"Bambu Lab P1S 0.4 nozzle"
; initial_layer_acceleration = 500
; initial_layer_flow_ratio = 1
; initial_layer_infill_speed = 105
; initial_layer_jerk = 9
; initial_layer_line_width = 0.5
; initial_layer_print_height = 0.2
; initial_layer_speed = 50
; inner_wall_acceleration = 0
; inner_wall_jerk = 9
; inner_wall_line_width = 0.45
; inner_wall_speed = 300
; interface_shells = 0
; internal_bridge_support_thickness = 0.8
; internal_solid_infill_line_width = 0.42
; internal_solid_infill_pattern = zig-zag
; internal_solid_infill_speed = 250
; ironing_flow = 10%
; ironing_pattern = zig-zag
; ironing_spacing = 0.15
; ironing_speed = 30
; ironing_type = no ironing
; layer_change_gcode = ; layer num/total_layer_count: {layer_num+1}/[total_layer_count]\nM622.1 S1 ; for prev firware, default turned on\nM1002 judge_flag timelapse_record_flag\nM622 J1\n{if timelapse_type == 0} ; timelapse without wipe tower\nM971 S11 C10 O0\n{elsif timelapse_type == 1} ; timelapse with wipe tower\nG92 E0\nG1 E-[retraction_length] F1800\nG17\nG2 Z{layer_z + 0.4} I0.86 J0.86 P1 F20000 ; spiral lift a little\nG1 X65 Y245 F20000 ; move to safe pos\nG17\nG2 Z{layer_z} I0.86 J0.86 P1 F20000\nG1 Y265 F3000\nM400 P300\nM971 S11 C11 O0\nG92 E0\nG1 E[retraction_length] F300\nG1 X100 F5000\nG1 Y255 F20000\n{endif}\nM623\n; update layer progress\nM73 L{layer_num+1}\nM991 S0 P{layer_num} ;notify layer change
; layer_height = 0.2
; line_width = 0.42
; machine_end_gcode = ;===== date: 20230428 =====================\nM400 ; wait for buffer to clear\nG92 E0 ; zero the extruder\nG1 E-0.8 F1800 ; retract\nG1 Z{max_layer_z + 0.5} F900 ; lower z a little\nG1 X65 Y245 F12000 ; move to safe pos \nG1 Y265 F3000\n\nG1 X65 Y245 F12000\nG1 Y265 F3000\n\nM106 S0 ; turn off fan\nM106 P2 S0 ; turn off remote part cooling fan\nM106 P3 S0 ; turn off chamber cooling fan\n\nG1 X100 F12000 ; wipe\n; pull back filament to AMS\nM620 S255\nG1 X20 Y50 F12000\nG1 Y-3\nT255\nG1 X65 F12000\nG1 Y265\nG1 X100 F12000 ; wipe\nM621 S255\nM104 S0 ; turn off hotend\n\nM622.1 S1 ; for prev firware, default turned on\nM1002 judge_flag timelapse_record_flag\nM622 J1\n    M400 ; wait all motion done\n    M991 S0 P-1 ;end smooth timelapse at safe pos\n    M400 S3 ;wait for last picture to be taken\nM623; end of "timelapse_record_flag"\n\nM400 ; wait all motion done\nM17 S\nM17 Z0.4 ; lower z motor current to reduce impact if there is something in the bottom\n{if (max_layer_z + 100.0) < 220}\n    G1 Z222 F600\n    G1 Z220\n{else}\n    G1 Z250 F600\n    G1 Z248\n{endif}l\nM400 P100\nM17 R ; restore z current\n\nM140 S100 ;set bed temp heat bed to 100 to weaken magnet\nM190 S100 ;wait for bed temp\nM140 S0 ; turn off bed\n\nG90\nG1 X128 Y250 F3600\n\nM220 S100  ; Reset feedrate magnitude\nM201.2 K1.0 ; Reset acc magnitude\nM73.2   R1.0 ;Reset left time magnitude\nM1002 set_gcode_claim_speed_level : 0\n\nM17 X0.8 Y0.8 Z0.5 ; lower motor current to 45% power\n
; machine_load_filament_time = 29
; machine_max_acceleration_e = 5000,5000
; machine_max_acceleration_extruding = 20000,20000
; machine_max_acceleration_retracting = 5000,5000
; machine_max_acceleration_travel = 9000,9000
; machine_max_acceleration_x = 20000,20000
; machine_max_acceleration_y = 20000,20000
; machine_max_acceleration_z = 500,200
; machine_max_jerk_e = 2.5,2.5
; machine_max_jerk_x = 9,9
; machine_max_jerk_y = 9,9
; machine_max_jerk_z = 3,3
; machine_max_speed_e = 30,30
; machine_max_speed_x = 500,200
; machine_max_speed_y = 500,200
; machine_max_speed_z = 20,20
; machine_min_extruding_rate = 0,0
; machine_min_travel_rate = 0,0
; machine_pause_gcode = M400 U1
; machine_start_gcode = ;===== machine: P1S ========================\n;===== date: 20230707 =====================\n;===== turn on the HB fan =================\nM104 S75 ;set extruder temp to turn on the HB fan and prevent filament oozing from nozzle\n;===== reset machine status =================\nG91\nM17 Z0.4 ; lower the z-motor current\nG380 S2 Z30 F300 ; G380 is same as G38; lower the hotbed , to prevent the nozzle is below the hotbed\nG380 S2 Z-25 F300 ;\nG1 Z5 F300;\nG90\nM17 X1.2 Y1.2 Z0.75 ; reset motor current to default\nM960 S5 P1 ; turn on logo lamp\nG90\nM220 S100 ;Reset Feedrate\nM221 S100 ;Reset Flowrate\nM73.2   R1.0 ;Reset left time magnitude\nM1002 set_gcode_claim_speed_level : 5\nM221 X0 Y0 Z0 ; turn off soft endstop to prevent protential logic problem\nG29.1 Z{+0.0} ; clear z-trim value first\nM204 S10000 ; init ACC set to 10m/s^2\n\n;===== heatbed preheat ====================\nM1002 gcode_claim_action : 2\nM140 S[bed_temperature_initial_layer_single] ;set bed temp\nM190 S[bed_temperature_initial_layer_single] ;wait for bed temp\n\n\n\n;=============turn on fans to prevent PLA jamming=================\n{if filament_type[initial_extruder]=="PLA"}\n    {if (bed_temperature[initial_extruder] >45)||(bed_temperature_initial_layer[initial_extruder] >45)}\n    M106 P3 S180\n    {elsif (bed_temperature[initial_extruder] >50)||(bed_temperature_initial_layer[initial_extruder] >50)}\n    M106 P3 S255\n    {endif};Prevent PLA from jamming\n{endif}\nM106 P2 S100 ; turn on big fan ,to cool down toolhead\n\n;===== prepare print temperature and material ==========\nM104 S[nozzle_temperature_initial_layer] ;set extruder temp\nG91\nG0 Z10 F1200\nG90\nG28 X\nM975 S1 ; turn on\nG1 X60 F12000\nG1 Y245\nG1 Y265 F3000\nM620 M\nM620 S[initial_extruder]A   ; switch material if AMS exist\n    M109 S[nozzle_temperature_initial_layer]\n    G1 X120 F12000\n\n    G1 X20 Y50 F12000\n    G1 Y-3\n    T[initial_extruder]\n    G1 X54 F12000\n    G1 Y265\n    M400\nM621 S[initial_extruder]A\nM620.1 E F{filament_max_volumetric_speed[initial_extruder]/2.4053*60} T{nozzle_temperature_range_high[initial_extruder]}\n\n\nM412 S1 ; ===turn on filament runout detection===\n\nM109 S250 ;set nozzle to common flush temp\nM106 P1 S0\nG92 E0\nG1 E50 F200\nM400\nM104 S[nozzle_temperature_initial_layer]\nG92 E0\nG1 E50 F200\nM400\nM106 P1 S255\nG92 E0\nG1 E5 F300\nM109 S{nozzle_temperature_initial_layer[initial_extruder]-20} ; drop nozzle temp, make filament shink a bit\nG92 E0\nG1 E-0.5 F300\n\nG1 X70 F9000\nG1 X76 F15000\nG1 X65 F15000\nG1 X76 F15000\nG1 X65 F15000; shake to put down garbage\nG1 X80 F6000\nG1 X95 F15000\nG1 X80 F15000\nG1 X165 F15000; wipe and shake\nM400\nM106 P1 S0\n;===== prepare print temperature and material end =====\n\n\n;===== wipe nozzle ===============================\nM1002 gcode_claim_action : 14\nM975 S1\nM106 S255\nG1 X65 Y230 F18000\nG1 Y264 F6000\nM109 S{nozzle_temperature_initial_layer[initial_extruder]-20}\nG1 X100 F18000 ; first wipe mouth\n\nG0 X135 Y253 F20000  ; move to exposed steel surface edge\nG28 Z P0 T300; home z with low precision,permit 300deg temperature\nG29.2 S0 ; turn off ABL\nG0 Z5 F20000\n\nG1 X60 Y265\nG92 E0\nG1 E-0.5 F300 ; retrack more\nG1 X100 F5000; second wipe mouth\nG1 X70 F15000\nG1 X100 F5000\nG1 X70 F15000\nG1 X100 F5000\nG1 X70 F15000\nG1 X100 F5000\nG1 X70 F15000\nG1 X90 F5000\nG0 X128 Y261 Z-1.5 F20000  ; move to exposed steel surface and stop the nozzle\nM104 S140 ; set temp down to heatbed acceptable\nM106 S255 ; turn on fan (G28 has turn off fan)\n\nM221 S; push soft endstop status\nM221 Z0 ;turn off Z axis endstop\nG0 Z0.5 F20000\nG0 X125 Y259.5 Z-1.01\nG0 X131 F211\nG0 X124\nG0 Z0.5 F20000\nG0 X125 Y262.5\nG0 Z-1.01\nG0 X131 F211\nG0 X124\nG0 Z0.5 F20000\nG0 X125 Y260.0\nG0 Z-1.01\nG0 X131 F211\nG0 X124\nG0 Z0.5 F20000\nG0 X125 Y262.0\nG0 Z-1.01\nG0 X131 F211\nG0 X124\nG0 Z0.5 F20000\nG0 X125 Y260.5\nG0 Z-1.01\nG0 X131 F211\nG0 X124\nG0 Z0.5 F20000\nG0 X125 Y261.5\nG0 Z-1.01\nG0 X131 F211\nG0 X124\nG0 Z0.5 F20000\nG0 X125 Y261.0\nG0 Z-1.01\nG0 X131 F211\nG0 X124\nG0 X128\nG2 I0.5 J0 F300\nG2 I0.5 J0 F300\nG2 I0.5 J0 F300\nG2 I0.5 J0 F300\n\nM109 S140 ; wait nozzle temp down to heatbed acceptable\nG2 I0.5 J0 F3000\nG2 I0.5 J0 F3000\nG2 I0.5 J0 F3000\nG2 I0.5 J0 F3000\n\nM221 R; pop softend status\nG1 Z10 F1200\nM400\nG1 Z10\nG1 F30000\nG1 X230 Y15\nG29.2 S1 ; turn on ABL\n;G28 ; home again after hard wipe mouth\nM106 S0 ; turn off fan , too noisy\n;===== wipe nozzle end ================================\n\n\n;===== bed leveling ==================================\nM1002 judge_flag g29_before_print_flag\nM622 J1\n\n    M1002 gcode_claim_action : 1\n    G29 A X{first_layer_print_min[0]} Y{first_layer_print_min[1]} I{first_layer_print_size[0]} J{first_layer_print_size[1]}\n    M400\n    M500 ; save cali data\n\nM623\n;===== bed leveling end ================================\n\n;===== home after wipe mouth============================\nM1002 judge_flag g29_before_print_flag\nM622 J0\n\n    M1002 gcode_claim_action : 13\n    G28\n\nM623\n;===== home after wipe mouth end =======================\n\nM975 S1 ; turn on vibration supression\n\n\n;=============turn on fans to prevent PLA jamming=================\n{if filament_type[initial_extruder]=="PLA"}\n    {if (bed_temperature[initial_extruder] >45)||(bed_temperature_initial_layer[initial_extruder] >45)}\n    M106 P3 S180\n    {elsif (bed_temperature[initial_extruder] >50)||(bed_temperature_initial_layer[initial_extruder] >50)}\n    M106 P3 S255\n    {endif};Prevent PLA from jamming\n{endif}\nM106 P2 S100 ; turn on big fan ,to cool down toolhead\n\n\nM104 S{nozzle_temperature_initial_layer[initial_extruder]} ; set extrude temp earlier, to reduce wait time\n\n;===== mech mode fast check============================\nG1 X128 Y128 Z10 F20000\nM400 P200\nM970.3 Q1 A7 B30 C80  H15 K0\nM974 Q1 S2 P0\n\nG1 X128 Y128 Z10 F20000\nM400 P200\nM970.3 Q0 A7 B30 C90 Q0 H15 K0\nM974 Q0 S2 P0\n\nM975 S1\nG1 F30000\nG1 X230 Y15\nG28 X ; re-home XY\n;===== fmech mode fast check============================\n\n\n;===== noozle load line ===============================\nM975 S1\nG90\nM83\nT1000\nG1 X18.0 Y1.0 Z0.8 F18000;Move to start position\nM109 S{nozzle_temperature_initial_layer[initial_extruder]}\nG1 Z0.2\nG0 E2 F300\nG0 X240 E15 F{outer_wall_volumetric_speed/(0.3*0.5)     * 60}\nG0 Y11 E0.700 F{outer_wall_volumetric_speed/(0.3*0.5)/ 4 * 60}\nG0 X239.5\nG0 E0.2\nG0 Y1.5 E0.700\nG0 X18 E15 F{outer_wall_volumetric_speed/(0.3*0.5)     * 60}\nM400\n\n;===== for Textured PEI Plate , lower the nozzle as the nozzle was touching topmost of the texture when homing ==\n;curr_bed_type={curr_bed_type}\n{if curr_bed_type=="Textured PEI Plate"}\nG29.1 Z{-0.04} ; for Textured PEI Plate\n{endif}\n;========turn off light and wait extrude temperature =============\nM1002 gcode_claim_action : 0\nM106 S0 ; turn off fan\nM106 P2 S0 ; turn off big fan\nM106 P3 S0 ; turn off chamber fan\n\nM975 S1 ; turn on mech mode supression
; machine_unload_filament_time = 28
; max_bridge_length = 10
; max_layer_height = 0.28
; max_travel_detour_distance = 0
; min_bead_width = 85%
; min_feature_size = 25%
; min_layer_height = 0.08
; minimum_sparse_infill_area = 15
; nozzle_diameter = 0.4
; nozzle_temperature = 220
; nozzle_temperature_initial_layer = 220
; nozzle_temperature_range_high = 240
; nozzle_temperature_range_low = 190
; nozzle_type = stainless_steel
; nozzle_volume = 107
; only_one_wall_first_layer = 0
; ooze_prevention = 0
; outer_wall_acceleration = 5000
; outer_wall_jerk = 9
; outer_wall_line_width = 0.42
; outer_wall_speed = 200
; overhang_1_4_speed = 0
; overhang_2_4_speed = 50
; overhang_3_4_speed = 30
; overhang_4_4_speed = 10
; overhang_fan_speed = 100
; overhang_fan_threshold = 50%
; post_process =
; pressure_advance = 0.02
; prime_tower_brim_width = 3
; prime_tower_width = 35
; prime_volume = 45
; print_compatible_printers = "Bambu Lab X1 Carbon 0.4 nozzle";"Bambu Lab X1 0.4 nozzle";"Bambu Lab P1S 0.4 nozzle";"Bambu Lab X1E 0.4 nozzle"
; print_flow_ratio = 1
; print_host =
; print_host_webui =
; print_sequence = by layer
; print_settings_id = 0.20mm Standard @BBL X1C
; printable_area = 0x0,256x0,256x256,0x256
; printable_height = 220
; printer_model = Bambu Lab P1S
; printer_settings_id = Bambu Lab P1S 0.4 Robot Integration
; printer_structure = corexy
; printer_technology = FFF
; printer_variant = 0.4
; printhost_apikey =
; printhost_authorization_type = key
; printhost_cafile =
; printhost_password =
; printhost_port =
; printhost_ssl_ignore_revoke = 0
; printhost_user =
; raft_contact_distance = 0.1
; raft_expansion = 1.5
; raft_first_layer_density = 90%
; raft_first_layer_expansion = 2
; raft_layers = 0
; reduce_crossing_wall = 0
; reduce_fan_stop_start_freq = 1
; reduce_infill_retraction = 1
; required_nozzle_HRC = 3
; resolution = 0.012
; retract_before_wipe = 0%
; retract_length_toolchange = 2
; retract_lift_above = 0
; retract_lift_below = 249
; retract_restart_extra = 0
; retract_restart_extra_toolchange = 0
; retract_when_changing_layer = 1
; retraction_length = 0.8
; retraction_minimum_travel = 1
; retraction_speed = 30
; scan_first_layer = 0
; seam_gap = 15%
; seam_position = aligned
; silent_mode = 0
; single_extruder_multi_material = 1
; skirt_distance = 2
; skirt_height = 1
; skirt_loops = 0
; slice_closing_radius = 0.049
; slicing_mode = regular
; slow_down_for_layer_cooling = 1
; slow_down_layer_time = 8
; slow_down_min_speed = 20
; solid_infill_filament = 1
; sparse_infill_acceleration = 100%
; sparse_infill_anchor = 400%
; sparse_infill_anchor_max = 20
; sparse_infill_density = 35%
; sparse_infill_filament = 1
; sparse_infill_line_width = 0.45
; sparse_infill_pattern = grid
; sparse_infill_speed = 270
; spiral_mode = 0
; standby_temperature_delta = -5
; start_end_points = 30x-3,54x245
; support_air_filtration = 0
; support_angle = 0
; support_base_pattern = default
; support_base_pattern_spacing = 2.5
; support_bottom_interface_spacing = 0.5
; support_bottom_z_distance = 0.2
; support_chamber_temp_control = 0
; support_critical_regions_only = 0
; support_expansion = 0
; support_filament = 0
; support_interface_bottom_layers = 2
; support_interface_filament = 0
; support_interface_loop_pattern = 0
; support_interface_pattern = auto
; support_interface_spacing = 0.5
; support_interface_speed = 80
; support_interface_top_layers = 2
; support_line_width = 0.42
; support_object_xy_distance = 0.35
; support_on_build_plate_only = 0
; support_remove_small_overhang = 1
; support_speed = 150
; support_style = default
; support_threshold_angle = 30
; support_top_z_distance = 0.2
; support_type = normal(auto)
; temperature_vitrification = 45
; template_custom_gcode =
; textured_plate_temp = 55
; textured_plate_temp_initial_layer = 55
; thick_bridges = 0
; thumbnail_size = 50x50
; time_lapse_gcode =
; timelapse_type = 0
; top_one_wall_type = all top
; top_shell_layers = 3
; top_shell_thickness = 0.6
; top_solid_infill_flow_ratio = 1
; top_surface_acceleration = 2000
; top_surface_jerk = 9
; top_surface_line_width = 0.42
; top_surface_pattern = monotonicline
; top_surface_speed = 200
; travel_jerk = 9
; travel_speed = 500
; travel_speed_z = 0
; tree_support_branch_angle = 45
; tree_support_branch_diameter = 2
; tree_support_branch_distance = 5
; tree_support_brim_width = 0
; tree_support_wall_count = 1
; upward_compatible_machine = "Bambu Lab P1P 0.4 nozzle";"Bambu Lab X1 0.4 nozzle";"Bambu Lab X1 Carbon 0.4 nozzle";"Bambu Lab X1E 0.4 nozzle"
; use_relative_e_distances = 1
; wall_distribution_count = 1
; wall_filament = 1
; wall_generator = classic
; wall_infill_order = inner wall/outer wall/infill
; wall_loops = 2
; wall_transition_angle = 10
; wall_transition_filter_deviation = 25%
; wall_transition_length = 100%
; wipe = 1
; wipe_distance = 2
; wipe_speed = 80%
; wipe_tower_no_sparse_layers = 0
; wipe_tower_rotation_angle = 0
; wipe_tower_x = 155
; wipe_tower_y = 220
; xy_contour_compensation = 0
; xy_hole_compensation = 0
; z_hop = 0.4
; z_hop_types = Auto Lift
; CONFIG_BLOCK_END
; EXECUTABLE_BLOCK_START
M73 P0 R76
M201 X20000 Y20000 Z500 E5000
M203 X500 Y500 Z20 E30
M204 P20000 R5000 T20000
M205 X9.00 Y9.00 Z3.00 E2.50
M106 S0
M106 P2 S0
; FEATURE: Custom
G91
G380 S2 Z-25 F300 ;
G1 Z5 F300;
G90
G90
G29.1 Z0 ; clear z-trim value first
M73 P0 R76
G28 ; Home all axes
G1 Z220 F600 ; Move to Z 220
G1 Z76.1 F900 ; lower z a little
G1 Y265 F3000
G1 X65 Y245 F12000
G1 Y265 F3000
M17 S
    G1 Z222 F600
    G1 Z220
l
M400 P100
G90
G1 X128 Y250 F3600
M141 S0;set chamber_temperature
M73 P100 R0
; EXECUTABLE_BLOCK_END
From the top of my head you should need only three commands:
G28 ; home all axes
G90 ; set absolute positioning
G0 Z220 ; linear move to z=220mm
EDIT: Tried this with my X1C and it doesn’t work.
And I had to power cycle the printer, because cancelling also doesn’t work.
You may be over complicating the issue.
You can do this with a simple .gcode file run from the SD card.
This is a modified version of the bed tramming gcode provided by Bambu.
M17 X1.2 Y1.2 Z0.75 ; enable and set stepper current
G90
G28 ; home all axis
G1 X128 Y128 Z220 ; move to center and lower the bed
Change the extension from .3mf to .gcode (I changed to .3mf to be able to upload the file.)
Homeandlowerbed.3mf (111 Bytes)
Thank you, I will try this, I also want it to update the printer status from starting to finished do I just add the following to the start/end?
M73 P0 R1
M73 P100 R0
I’m assuming you’re referring to Marlin’s M73? This isn’t supported by Bambu.
The best Bambu specific gcode reference I’ve found is here.
that’s an awesome resource thank you, m73 is mentioned in that list though so it should work I think
Oh you are right! Let me know if you have any luck getting it to work.
The gcode file works perfect, only issue is that I can’t start gcode files over mqtt only 3mf(at least I can’t figure out how), so it won’t really work for what I’m trying to do unfortunately.
If you have a windows machine, you can send any file to the printer using winscp.
Let me know if you need directions.
Another way is to make a custom printer profile, remove all of the Start GCode, and put your GCode in its place.
Only do this if you are confident you won’t do any damage, of course.
