Get around the filament restrictions (PVA) regarding 0.2mm nozzle
TL;DR Is there a way to circumvent the restriction of using certain filaments in combination with a 0.2mm nozzle?
Hello,
So as some of you may already noticed, Bambu Studio is getting new updates now and then, some for the good, some are really bad. One of these is not having the free choice to select which filament you want to use for your 0.2mm nozzle.
So nowadays when you select a 0.2mm nozzle, filaments will disappear from the filament list because Bambu doesn’t seem them fit for that size of nozzle. No matter if it is Not recommended or straight up incompatible.
Sure, I can imagine that Bambu put these restrictions to protect new users against making certain mistakes, especially with a prone-to-clogging 0.2mm nozzles.
But as some might agree, not every user is new, not every user is clueless how to use their printer etc. We don’t always need Bambu to babysit us along the way. And since the departure from Orca this has become even worse.
I mean, after printing for 3 years and 5 printers later with variety of nozzles and filaments, making mistakes and learning from them, I’m quite confident I’m a big boy who can make his own descisions how to use his own printer.
So just a simple question: is there a way to circumvent the restriction of using certain filaments in combination with a 0.2mm nozzle?
The only other way I think that would work is to make a “PLA” profile with the right values to trick the slicer.
Bonus question, does also someone know what the new “Use cooling filter” in Printer settings does? Is it in regards to the new frontcover fan?
I just got an incompatibility error for silk PLA, even though Bambu’s own documentation says it’s fine.
