Getting G Code Message dispite having setting correct
Since I last updated the firmware on my P1P, I have been getting a G-Code message when sending the print job to the printer stating that the G-Code is not correct. The correct printer, plate and nozzle are all selected. I have seen other P1P users talk about this on reddit but, alas no suggestions on how to troubleshoot it or see what the root issue is. Wanted to post here in the actual forum to see if there are any suggestions or if this could be a bug.
Any help is appreciated.
Check a setting in Handy app, under accesories → enclosure kit, click disable. This should cancel this error.
Unless of course, you actually have the P1P enclosure kit installed :slight_smile:
In that case that option should remain enabled, but you’d need to select the P1S instead of the P1P in the slicer.
so should i rename it p1s2 and slice it as a p1s?
