Glass build plate
Yeah sure. That is arguably better. Depends on temp shifts and how easily the print will release once the glass cools. Personally I avoid glass altogether if I’m not printer on the CR-10…
I would assume all beds are warped to various degrees, right? I need a perfectly flat surface as well as perfectly perpendicular to the hotend.
As you say, any bed is warped and misaligned to a certain degree. When you say “perfect”, you need to specify the tolerance you require. Because you will not find the “perfect” surface.
I just bought a 257 x 257 glass build sheet for my A1 on Amazon. Can you just clip it to the build plate with those binder clips or what?
I got one on Amazon for under $20. But I don’t know how to use it. Do you just clip it on? And do you set the heat the same?
You may wish to just clip it on, but make sure that they do not interfere with the printer’s movement; alternatively you can use some high-temperature double-sided tape or a thin layer of silicone adhesive for a more permanent solution (to remove it you can just heat the silicon at a high temperature and then pry it, or you can use a solvent such as isopropyl alcohol).
Since you are using a tempered glass bed, you do not need to worry about the temperature damaging the glass (as long as you keep the standard build plate temperatures); though if you choose to use the silicone adhesive you should keep the temperatures lower than ~115ºC (remember to check the silicon adhesive recommended temperature use) but it should not be a problem since the max build plate temperature of the A1 is 100ºC, so you don’t have to worry about it.
Clamps on the print bed usually cause problems. Force sensors that don’t measure correctly or the clamps collide somewhere on the printer. The best option I found, and which others also use, is to take a magnetic plate as a base and stick the glass plate onto it. I used thin paper tape on both sides to stick it on. It’s a bit of tinkering because my glass plate isn’t the exact size, but it works.
With glass, however, it is important to note that certain filaments are easier to detach from it than others. That’s why I only use glass when I need it and for filaments that tend to warp more (as they also detach more easily from the glass when they cool down).
When you start crafting, remember that wood and paper are very heat-resistant in relation to 3D printing. This is why paper tape also works.
Best regards and happy holidays!
Office paper clips :wink:
There is always a size that fits, although they get longer and wider with size.
Take the spring clips for the fingers off once set on the plate and nothing will obstruct if you make sure they are not place in a spot where the head would go.
WAY overpriced! Should be under $30.
Thanks for the advice! I’ll give it a shot!
Are there any problems leveling the bed using glass?
Only if it is not balanced correctly (for example, if you do not apply the high-temperature double-sided tape symmetrically).
Hello, I would also like to use a 4mm thick glass plate as a printing plate. Can I just put the plate in and print? Do I have to change the Z offset in G-code because of the thicker plate? I would be very happy to receive answers. Thanks in advance
