Using my ultra slow PETG profile (40mm/s)
250 degrees
5 wall loops
5 top and bottom shell layers
15% Gyroid infill and also tried 15% Cross Hatch
I also tried using my ironing calibration test… that clogged the extruder and nozzle (by the time it hit the 35% flow rate) so bad it was the worst clog I’ve ever encountered. Had to completely disassemble the whole extruder assembly (all 8 screws) and heat the nozzle up to 300 to push the clog out the top with a needle. None of the ironing that printed looked all that good, so I gave up on the ironing.
I’d be happy to just eliminate the bump on the surface.
It makes great strong parts… just trying to pretty them up a little bit more.
The bubbles looks like bridging sag underneath and the nature of PETG balling up making it worse. I’d be inclined to speed up the print a little and change the top surface to Monotonic line or similar to get a more uniform look (turn the model to get a more appealing angle).
Well it’s got “meh” ratings with most people saying it’s difficult to work with. I’ve never used PETG-GF but I’ve used PETG and ABS-GF and I’ve mostly seen issues when wet.
