Glue question (not for adhession)
So, it might not be fitting for BL, but on the other hand it’s needed for my BL printer.
I bought some LEDstrips from Ali, to connect with the BL Led controller from DutchDevelor. Now it seems that the sticky part on the back side of the LED’s aren’t sticky. Seller told me to use some glue, but I wonder what kind of glue would be safe to use inside the printer (LED raiser)
You can buy 3M double sided LED strip tape.
Thanks. Didn’t even know such a thing existed.
While you’re at it, you might want to consider one of the new “dotless” led strips. It provides more uniform, continuous lighting by avoiding the glare of typical point source leds soldered to your typical, generic led strip. It probably also comes with a peel-off adhesive backing already built-in.
