H2 Printer minimum ambient temperature
To deal with fumes, I’m considering using a H2D or H2C printer in an unheated (but insulated) attached garage. The temperature can get as low as about 40ª F during the winter. What is the minimum ambient temperature for the printer. I mostly print PLA.
Can the printer be insulated to allow for a lower ambient temperature?
Thanks,
Mark
From the specs, the working temp range is 10C-30C, so you’re below that range.
I could see an issue with lubricants being too viscous and causing excess drag, that could be mitigated with a longer heatup period prior to printing. Heck, you could even make a custom printer profile that does a max temp heatsoak for 15 minutes prior to starting the print.
The other thing you’ll want to look at is how the top vent behaves - I believe the printer always wants to keep the exhaust fan at 30% and top vent open for PLA, as an example. That would be an issue.
Insulating the printer wouldn’t be an issue as long as the electronics are kept cool and it can still manage it’s own chamber temp to avoid heat creep or excess material shrinkage.
