H2C ams broken?
Was doing a print, it ran out of filament and when I inserted a new roll it keeps saying that it failed to pull out filament and the ams pro makes this noise from the video? I do not understand what is happening to it, overall this is the 4th issue I’ve had with the H2C in under a few months.. the video I had to upload really low quality so it is under 5mb
VID_20261012_123430_2
Also I saw some forums saying that there is a bad batch of ams pro 2’s that coincides around when I bought the H2C. Could it be one of those?
probably a bit of filament stuck in the device. most reels have the filament tail locked with a 90° bend, personally never had issues ending them
there seems to be no fillament visibily stuck anywhere, unless it is stuck in the hub? I do not see how normal PLA could have gotten stuck in there
I can’t push fillament trough the hub from any of the 4, unless i press the manual spring button, then it really hardly goes trough.
yes the spring has to be pushed in continuously. In two cases I managed to get the little piece out without fully disassembling everything at the bottom. I lifted up the inside of the AMS and tried pushing some PETG through by hand, and in the end a bit of red PLA came out. But I consider myself lucky. The first time I had to take apart the end section where the drive motor is. I wouldn’t wish that on you.
be sure you need to remove all inner short white tubes, so you can try pushing some petg that has to pass through normally if there are no clogs
Do you think ASA would be better to push, as it is harder? and do i push just in the holes left after removing the small tubes in the ams?
Yes, it’s like flossing the AMS… gently. The filament has to pass all the way through, end to end, that’s your guarantee there’s no debris left inside. And we’re talking about the AMS 2 Pro here, okay?
here AMS 2 Pro Broken Filament Removal and Internal Hub Sensor Check | Bambu Lab Wiki
yep yep ams 2 pro, i will try now
i tried with ASA, i pushed it trough, it felt a bit stuck, but it eventually went trough, nothing came out apart from the ASA, i put PLA back in and it still has the same error, im guessing it is something else.
you purged the upper part where the spool goes in ?
those are all clear, the problem only surfaces at the hub, the 4 motors are ok. I think that is what you mean?
yes and if the last bit of filament snapped stuck on the sprockets you may just unclog it inserting a filament into the buffer from the outside
i checked them and they are fine, the fillament can go in them from any way, the problem still seems to be in the hub :frowning:
I have talked to bambu and they shipped a new hub unit for the ams pro.
I tried to insert filament from external spool but i think there is also something broken in the tool head, is there any way to clear a blockage without disassembly of the entire thing?
I don’t know, happened twice to me. Initially it was a full dismount. then lately I already knew the pain so I just detached all tubes on the back and the plug to the outside, then i flipped the ams while trying to gently purge the hub with a resistant filment (petg in this case) and the red pla bit sprung out. I was just grateful for that.
