This is my first attempt to use the 0.2mm nozzle on the right side (induction). I’m using Bambu PLA matte filament.
I’m printing a model that is basically a board with numbers on it. On my first attempt, 2 hours into it it printed most of the board, then I got an error with extrude overloaded message. I had to stop the print, check the nozzle, remove the PLA, then test it again if it was extruding correctly, and it did.
So I tried again, and it started to print the first layer and the 1/2 way through it, no filament was coming out of he nozzle.
Is this a nozzle clog? Do I have to attempt the cold pull ?
Before we try to find the solution, why the problem happened in the first place? I thought PLA Matte was in the list of certified to work with 0.2 nozzle on the induction nozzle.
Did I miss anything?
Thank you,
