I finally decided to get the Filament Track Switch for my H2C and to put it to some real test, decided to go with Majora’s mask (a 36H print) and I have run into several issues so far:
My setup: H2C with 2 AMS PRO + Filament Tracker.
- For several times the printer complains about not being to pull filament out of the extruder, but after I press resume it works anyway (so it thinks it’s stuck but it’s not?)
- For several times, the printer give a mesage that the Filament Track Switch is not connected or missing or filament is stuck / tracker might be damaged but pressing resume make it work again.
- At one point the printer was trying to retract from the right nozzle without warming it up (while the left nozzle was the one that was active and had no filament in it), it almost looked liked it got the nozzles confused? The only way i could recover from it without wasting 22H of print time was to cut power off the printer and thankfully it started to take the right sequence of action (I am 100% sure that was a logic bug).
- I also keep getting message about feed resistance being two hight from either AMS. My Filament Tracker setup is pretty standard so I am not sure where the feed resistance even is.
This Filament Track Switch seems to be more trouble than it’s worth from my first experience. Anyone else had these issues? Once the print job finished I’ll examine “the tubes” I guess but nothing obvious jumps out.
Edit: Filament Track Switch not Filament Tracker. ![]()
