H2C Defaulting to 250c Loading Temp for PPS-CF
Anyone know how to fix this? Whenever I try to load PPS-CF (H2C, left 0.6 nozzle, stock profile with no changes, external spool) it defaults to 250c during loading which isn’t hot enough so it can’t load and just causes the extruder to click click click. I can stop the loading and manually set a higher temp and manually extrude it, but that isn’t a good long term solution for a few reasons. I’ve seen lots of people have had the same problem for a while now but no real fix to what has to be a Bambu studio slicer issue. It seems odd that Bambu wouldn’t have addressed this by now but I can’t figure out what else could be at fault other than slicer code.
Are you using the Bambu PPS-CF filament profile or the generic one?
The Bambu Lab PPS-CF stock profile
Have you configured PPS-CF as the material for the external spool?
It uses the defined min/max temperatures to define the loading temperature for manual loading.
Yes, it’s configured and shows the correct min/max temps in the profile but still defaults to 250c. That’s why I tend to think it’s a slicer error. I googled and found people having the same problem going back months but no real solution other than to just do everything manually.
The problem with that is if you have to change spools mid-print or if the filament breaks and you have to reload mid-print it just goes back to 250c and won’t let you change it. So you’re left stopping the print if that happens and losing all the filament you already printed.
Neither PPS nor PPA are declared in the Machine Start GCode for the H2C with the latest defaults. For the H3C, PPA is in fact mentioned, but PPS is not.
So I would not be surprised if a file sliced using the default Machine start GCode would try to use the homing temp of 250°C when trying to first load it.
I have not tried to use PPS in my H2C to date though. Only my Plus 4.
That definitely would explain it. Interesting. I’ll have to investigate this more, thanks.
I have printed PPS and PPA on the H2D. Both didn’t have any issues. I manually loaded both materials automatically. No slicer involved there.
Printing went fine also. It’s been a while though. So things might changed.
Currently not able to test as I am printing a large ASA job.
  1. The bypass slot holds a different filament or temperature range. The printer keeps its own record of what’s in the bypass slot. If it was set on the printer screen to another material, or never updated, the midpoint can be 250. For example, a 220–280 range gives exactly 250.
  2. In Studio’s Device tab, click the left external spool and set it to **Bambu PPS-CF @BBL H2C 0.6 nozzle. Check that the min/max show 310 / 340
  3. Check the same on the printer left nozzle manually.
Yes, that was puzzling to me too. Plenty of reports here of successfull PPS prints.
But I did notice some changes to some presets (most recently, 0.2mm max flow) so there are undocumented changes that can sneak in. Either from newly implemented changes, re-introducing past defaults/errors or something else entirely. Sadly, I am not much of an IT guy :smiling_face_with_tear:
