You mentioned earlier that power cycling causes the mapping to get lost.
If that is the case, a log file should be enough to provide that information.
However, you probably already provided that.
When you power cycle your printer, do you do that also for the AMS’s?
Because I see you have the laser version, I guess you ise the emergency stop to power off your printer. At least, that’s what I am doing (rarely though). The only times I power cycle my printer is for a necessary reboot or to trigger a Beta update.
So you might try to power it off with the power switch on the back of the printer. No clue if the emergency stop has a different effect.
If you have all the devices on one central power switch, you might consider to power on the devices individually (AMS’s first and then the printer) and power them down in reverse order.
Looking at your current setup, you should be able to temporarily create a setup that is similar to the one in the setup instructions. Though I doubt if the shorter tubes will change the situation, having tested it, should at least exclude that as a source of the problem.
You might have an issue with the controller board though.
