H2C heatbed temp error
Has anyone received a Heatbed Temperature error mid print on H2C or any H2 series, turned off printer waiting a few minutes and re used it no problem, had this show up 2 different times but was able to print high heat filaments multiple times without issue
Nope, that ain’t right.
You could check your cable connections but if this error keeps happening you should raise a ticket with support.
Ok, thanks will do, appreciate it
