H2C Long-Term Experience?
I’m looking for users who already have around 3000 to 4000+ print hours on their H2C and can share honest long-term experience.
Specifically, I’m interested in any issues that came up over time, especially regarding the Vortex system. One concern I have is that the hotends don’t seem to receive individual offsets, but instead rely on a single calibration. I haven’t found any option to set or calibrate offsets per hotend individually, so maybe I’m missing something. If that’s the case, I’d appreciate clarification.
So I’d like to hear real-world feedback:
  • Have you encountered issues with accuracy or consistency over time?
  • Any problems related to the Vortex system?
  • General reliability after heavy usage?
I’d appreciate detailed insights from people who are running these machines extensively.
There are two approaches for setting Z height - measure and compensate for each tool, or use a single calibration and tightly control nozzle positioning and individual nozzle length.
Because the H2C uses a left/right toolhead, keeping track of offsets for each nozzle would actually require a lot more active processing as the system would need to maintain six different offsets and apply them in real-time during a print. Not to mention, measuring each nozzle would take 6x as long for nozzle offset calibration purposes.
The drawbar system Bambu uses for holding nozzles in place is based on what industrial CNC machines use for toolholding, it’s very precise and reliable. From a manufacturing standpoint, controlling nozzle length to within a reasonable tolerance is also reasonably achievable. These aren’t really physically wearing parts, so overall I think this was the right design direction to take.
Okay, thanks for your explanation. I’m just used to it from the U1, which I only recently got, or rather multiple U1s, where I can set the offset for each head individually. It performs an initial calibration, and on top of that I can still manually fine-tune things at the docking position where the heads are picked up, in case something isn’t perfectly aligned, slightly off, or has worn over time.
That’s something I kind of miss here.
High degrees of user adjustability are beneficial with less robust designs, or lack of consistency across nozzle/toolhead batches. Snapmaker basically said they don’t have a design or production controls to be able to keep their stuff in tolerance when they added the ability to compensate for every toolhead.
I don’t understand why you would want that situation, but as a longtime Bambu user, that consistently has not been the company’s design philosophy, and it seems to be working out for them pretty well. The printers just work*, and that makes them suitable for a wide audience.
*Yes, we know about your H2C.
What matters to me here is long-term use.
Right now, everything is working fine. I have not observed any meaningful tolerance issues on the Snapmaker side. The nozzles behave consistently. When I run flow calibration, they produce effectively identical results.
In contrast, on the H2C, each nozzle ends up with a slightly different flow value. The differences are not huge, but they are clearly there, and that already indicates less consistency compared to Snapmaker.
My point is not about current performance, but about wear over time. Components will degrade. If we are talking about multiple toolheads and nozzles, you can easily end up with replacement costs in the range of ~260 euros.
In that situation, having system-level compensation becomes relevant. Snapmaker gives you the ability to adjust and compensate for these deviations as they develop. That reduces the need to immediately replace parts just to maintain print quality.
For context, I did encounter initial issues on both systems:
  • On the Snapmaker, my first problem was a preloaded or slightly misaligned Z leadscrew.
  • On the other machine, the spring responsible for belt tension on the X and Y axes was too weak. That caused repeated homing errors. Once I manually increased belt tension, the issue disappeared.
So these were hardware-related issues, not tolerance drift during normal operation.
So far, I have not seen any additional mechanical problems. Toolheads seat properly, lock in place correctly, and behave as expected.
From a purely economic perspective, the Snapmaker setup is clearly more efficient for me. I can run up to three toolheads in parallel, which significantly improves throughput and overall value.
That said, the H2C still impresses me in other areas. The overall design is very appealing, especially the multi-nozzle concept. Being able to keep, for example, a 0.6 mm and a 0.2 mm nozzle installed at the same time adds real flexibility, and the system is clearly designed to go beyond standard four-color printing.
So for me, this is a trade-off between long-term cost efficiency and system versatility.
Considering the H2C only came out in November, you may have a hard time finding many users with 3,000 to 4,000+ hours already. 3,000 hours is 125 full days of printing, so that would be close to nonstop use depending on when they got it.
I’m at just over 1,500 hours on mine, so not quite the range you’re asking for, but mine has been solid. Zero real issues, and honestly it has been the most reliable of my three Bambu printers: A1, H2D, and H2C. It’s almost all multicolor printing PLA/PETG.
On flow, I would not automatically read different values as worse consistency. Flow is not treated as one single global value on the H2C. It is tied heavily to the filament profile, but the machine also accounts for the active nozzle/toolhead. Different numbers between nozzles may just be the system measuring the real behavior of each path, not proof of worse consistency.
On offsets, the H2C does have dual nozzle/Vortek offset calibration. I have not seen a user-facing table where you manually enter separate offsets for every individual hotend, but I also do not think it is fair to say there is no correction happening.
Long-term wear is a fair question, but at 1,500 hours I have not seen accuracy drift, seating issues, lockup issues, or anything I would tie to the Vortek system. So far mine has stayed very consistent.
mine has around 200 hrs on it and its unreliable and faulty. this is also my third H2C unit, first one had full length scratches on the Y rods, second one was rejected due to this and a smashed side panel. third one sounds like a 1940s car with a loose fan belt (which is apparently acceptable) also they believe that a extruder not extruding error is because of the AMS despite the fact i wasn’t using an ams. im not having a great time tbh… and i really wanted this to work
Mine has 1300 hours and we received with a Hotend fan DOA and now, the fan has star to make a big noise, I need to change a second time the hotend fan and it’s a big job, not funny.
But I love it, no others problems. We use my H2C with 4 AMS, one in left nozzle and 3 on the right.
Oh my god, those are even worse issues than mine. Compared to that, mine looks like child’s play.
As I said, the process is still not finished. I still haven’t gotten my money back. Now PayPal made an internal mistake, reset everything, and I had to upload everything again. Now I have to go through the entire process with PayPal from the beginning and wait for decisions again. And now they’re waiting for Bambu Lab to give the OK. They completely messed it up.
I’m now going down a different route and will charge the money back through my bank. For me, this whole Bambu topic is basically completely done. I’m completely out. I’m switching to Snapmaker, getting the top cover from somewhere else, installing the heater, and that’s it. I’m not dealing with this kindergarten anymore.
And what I’m reading here, that people are getting sued because they prefer to use something else or unlock certain functions again, how ridiculous is that honestly?
If I buy a MacBook or an iPhone and install a different operating system on it, that’s my problem. I paid for the device. I don’t know what kind of rights Bambu thinks it has or what they think they are.
They can sell their stuff in Korea if they want to treat people however they like, but not in the EU. They should either disappear, leave people alone, or deliver proper products and handle complaints properly and follow EU consumer laws, or just stop altogether.
As I said, I’m completely done with Bambu. Same with PayPal, I’m done there too. From now on I’ll only use Klarna and only pay by invoice. If that’s not available, I won’t buy anything. Simple as that.
Otherwise only Amazon or AliExpress, they know how this works. Apart from that, this whole topic is completely finished for me.
Honestly, my nerves are too valuable to deal with companies like this.
Did you mean to respond to me?
Hot end cooling. After 1000hrs of 65C chamber temps it started making bad noises. Not expensive but a bit of pain to change. 40min or so. Common problem it seems.
Only other issue I had was it lost it’s bed level/tram. Took me a bit to figure out what was going. I had to retram it for some reason. All good now.
Common issues were hotend cooling fan. You can expect a ~1000-3000hrs replacement cycle if you print in high temperature filaments very often. Each time it takes about 20-40 minutes depending on your skill level. Fastest record I’ve seen is 10-15 minutes by someone I respected a lot. For beginners that would be absolute nightmare tbh.
However, if you mainly print PLA/PETG, that fan can last a very long time easily. If you only print high temp filaments occasionally there’s no worry about the fan in general either.
17 days - 128 hours. 0 issues. But…I don’t know what will happen after 1000+ hours.
There was one problem though. The left filament cutter leaver was rubbing against the toolhead chassis, causing a scratch on the leaver and stucking which resulted in error. Later I found out that leaver stucking was probably caused by PLA Silk +, it’s fumes made the toolhead internals sticky. I will never use Silk filaments again. Also the poop was all sticky. I have seen the 4-way splitter which has ‘‘filament cleaning rubber part’’ inside completely sticky like it was dipped in honey due to Silk filement usage. Best to avoid it.
About 2200 hours here, no major problems, Vortek system has been 100% trouble free.
Things that broke:
  1. Enhanced cooling fan latching clip broke.
  2. Dual filament guide and sensor, the PTFE retention clips broke.
  3. Nozzle offset calibration sensor broke.
All minor things that were easy to repair.
I had the hotend cover thingy get bent quite severely - it was bent completely backwards, but the machine even shipped with two spares, so just had to replace it.
There was a firmware update a couple of months ago about fixing an issue where the toolhead would take a path where it could collide with the wiping pad or some such during its init cycle before a print, I believe this is something that could have cuased my issue.
Been running my launch H2C nearly everyday, had a couple nozzle clogs on the left nozzle and had the enhanced toolhead fan replaced.
Also got my 2nd H2C which arrived with a faulty enhanced toolhead fan but the replacement has been fine.
No issues with Vortek, it seems more accurate than my U1 in regards to accuracy between nozzle offset.
Nightmare, that’s been our experience so far. Practically brand new, about 50hrs on the H2C probably 40 hrs of errors. Adhesion issues no matter what kind of plates, constant jamming, extruder, clogging, one message after another that I have to research every time to figure out what the problem is now. We’ve currently got the machine torn apart waiting on a response from customer service : extruder tool head and right side extruder arm. And this thing was expensive ! No schematics, no true manual, no one to call on the phone just poorly written confusing over informative articles in wiki and constant searching videos on YouTube. Very disappointed so far. Have 2 A1 machines that run pretty well so no its not a filament issue or lack of experience issue the whole H2C is poorly designed and a Nightmare to service. I hate to say it
ill take “stuff that never happened” for 50…
You need an address to send that $50 to ?? Or can you not afford that either ? Open ticket with bambu currently I uploaded pics to this post but post does not allow media for visual proof. Sorry fanboy, I really like bambu lab but the extruder tool head on H2C is poorly designed. Needs to be all metal not a bunch of plastic to jam and have filament melt to it
200.then
25252525252525252525
