H2C PETG don't stick on PLA support interface Issue
I use 1st layer of raft of PLA to avoid the Texture of the PEI plate on my part as I don’t want to use glue. However, the PETG Basic does not stick on the PLA basic layer. Filament is dry, Top Z distance=0, also try Bottom Z distance =0. Even PETG on PETG lines are not sticking.
If I print PETG as the support layer, and PLA as the main body, it sticks.
Anyone has that issue?
I try nearly 100 times of different configs, temperature, z hop style, exchanged left nozzle to a new one, right nozzle with different hotend.
I am curious it is the bug similar to H3C that a youtuber found. I also tried to do always nozzle calibration ON. However, the issue cannot be solved. I am very frustrated…
I am not at my computer, but did you check if the part is directly on the raft, or still floating above it.
I used a raft only once and I would guess it has it’s own offset, and is not using the support parameters.
For me I’d be thinking that PLA and PETG or not compatible meaning they don’t stick to each other, which I realise is why you are doing it.
This is ideal for a “support interface” for example where there is a bridge. But if the whole of the PETG part is sat on a flat PLA raft I feel that it’s never going to be a strong enough grip.
I’d look for smooth plates for PETG rather than trying what you are trying.
