My H2C printer isn’t priming properly when I start a print with the left extruder (external spool). It’s not priming Line properly and the filament isn’t feeding correctly. However, with the right extruder, there are no problems the priming line is correct.
Did you get any resolution to this? I’m also having a similar problem where the purge line doesnt come out, just a couple of blobs and then the first line of the print is under extruded. Its completely find after that so it doesnt seem like a clog. This seems to be happening on every print.
I too am now having this issue seemingly out of the blue. Everything has been fine for weeks, but now my left nozzle isn’t printing the purge line (even though it tries) and filament doesn’t seem to come out until about ~5 seconds into the print.
I am having exactly the same issue lately. Have you found a solution ? I have checked the extruder gear and everything, but nothing it jammed. And the PTFE tube of the left nozzle is the shortest of both, so I don’t think this is the issue.
Same issue when I feed PA6-CF/PPA-CF to the left nozzle via external spool. I have to enable a 2 or 3 loop skirt to make sure I have filament when the print starts.
Did anyone ever figure out a workaround for this? I’m running into the exact same issue on a brand new H2C. Whenever I start a print with the left nozzle, it tries to lay down a purge line, but no filament comes out for the first 5 seconds or so.
Just wanted to follow up here since I got it sorted out. I ended up adding a conditional check in the machine start G code to bump up the prime distance specifically for the left nozzle.
Because the left side uses that separate lifting mechanism, it seems to need a bit more extrusion at the very start to build pressure compared to the right side. Bumping up the initial prime values right in the slicer fixed the blank start completely.
You want to find this original section in your Machine Start G-code (under the nozzle load line part):
Same issue on H2C when printing PA6-CF from external spool on left nozzle. My workaround was also the skirt loop. Thought, until I found all these comments, it was my fault.
