the first time i used the supertack plate on the H2C it went just fine, but ever since i always get the same error:
“Detected build plate offset or debris. Please align the build plate with the heatbed and remove all debris from the plate surface before continuing”
Every time i confirm there is no alignment issue, and of course the plate is clean from debris, so not sure what is going on there, i always hit ignore and it moves along and prints just fine, it’s actually a pretty decent plate, i’m enjoying it, love the surface finish and the adhesion is great with pla
had this error a few times on my normal plate… i just clean the plate and retry mostly works… guess about 4 times in 250 hours… seems for me unrelated to the new plate that worked fine so far.
It happens here from time to time… but also with the PEI. I think, the plate recognition is too sensible. Mostly it’s caused by the plate went down a tiny bit to far to the right or left.
My printer sits under a window and if the light comes through the curtain a certain way I get debris on build plate errors from the light and shadows cast on the build plate.
